Frickus
Joined: 09/21/2014 Posts: 13 Karma: +1 / -0 Location: Wolfsburg
03-12-2014, 14:02 Subject: |
Okay, I didn't know that. If the DPF has any additional problems, wouldn't the warning light come on? Or am I mistaken?
matthiasTDI96 Profi-Schrauber
03-12-2014, 14:22 Subject: |
According to my understanding, it referred to the fact that there was visible exhaust coming from the vehicle. This exhaust should, ideally, be largely retained by a functioning DPF (Diesel Particulate Filter). In your specific case, this would likely have resulted in a significant buildup of soot in the DPF.
And yes, if it's a closed system, it monitors the differential pressure, and depending on the condition, you will be notified.
Frickus
07-12-2014, 15:54 Subject: |
Okay, here's a general question for everyone: The EGR valve has been replaced, and the engine is running again. Now, I want to read the DPF loading status from measuring block 75, but unfortunately, no measuring blocks appear for me in blocks 70-75. Could it be that the DPF is disconnected, or am I driving in the wrong zones?
01 - Motor electronics -> 08 - Measurement data blocks -> Measurement data block 75.
It's not just that no value appears; in my case, the "Motor Vehicle Base" (MWB) isn't recognized. The engine is a 2.0 TDI BRE from 2006, installed in an Audi A4 Avant. Best regards.
Autoservice Profi-Schrauber
08-12-2014, 2:46 Subject: |
Am I mistaken, or is a DPF not necessarily installed in all BRE vehicles, but rather only retrofitted?
That would then also explain the Russian declension described in the error message...  LG, Onkel BM
08-12-2014, 7:59 Subject: |
. . . and the missing molecular weight biomarkers specific to cork  . Gruß Ulf
Profile PM Garage |
Hans Dampf
Joined: 11/23/2007 Posts: 32 Karma: +9 / -0 Location: Vellmar 2013 Ford Galaxy Premium Support
13-12-2014, 20:43 Subject: |
The BRE (Diesel Particulate Filter) was not standard equipment initially, but it was only introduced from mid-2007 onwards. There wasn't one installed before.
Best regards, Benny. Audi A4 AKE
Profile PM Garage |
Herbert Profi-Schrauber
13-12-2014, 21:40 Subject: |
Quote: | | So, he's definitely not removed, because it's still stuck inside. According to the previous owner, the DPF has also been replaced, and Audi confirmed this, as it was done there. |
Is that a retrofit DPF?
Herbert. Horch A4 8K CJCD
Frickus
dieselschrauber likes this. |
26-02-2015, 11:20 Subject: |
It's been a while, and I've already sold the car, but I still wanted to let you know about the issue. The EGR valve was the cause. The weld on the flap on the shaft had broken, so while the EGR valve was being activated, it no longer functioned. I replaced the EGR valve, cleared the learned values, and after that, the engine ran smoothly again, with no more signs of soot. Thank you very much to everyone for the help.
Best regards, Chris.
26-02-2015, 11:22 Subject: |
Thank you for the clarification! Gruß Ulf
Profile PM Garage |
