P2458 - Diesel Particulate Filter, Regeneration Duration (Solution)
Post14-10-2015, 12:07    Subject: P2458 - Diesel Particulate Filter, Regeneration Duration Quote
The error code P2458 - Diesel Particulate Filter, Regeneration Time Exceeded - is triggered when the diesel particulate filter cannot regenerate and the necessary regeneration process exceeds a certain duration.
Possible causes:
- Diesel particulate filter is too full (ash).
- Incorrect readings from the exhaust temperature sensors, which should be checked for plausibility.
- A malfunction in the engine that prevents proper exhaust gas temperature and sufficient airflow for regeneration.
Ratings - P2458 - Diesel Particulate Filter, Regeneration Duration
Average rating: 3.67 - worst rating: 1 - best rating: 5 - number of ratings: 3 - View ratings
No new posts DPF & Environmental Zones: Quick FAQ Technical Articles
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts P2453 - Diesel Particulate Filter Pressure Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF for Audi A3 CAYC - Diesel Particulate Filter Diesel Engine Technology
No new posts A6 4F 3.0 TDI - Exhaust, Diesel Particulate Filter... Diesel Engine Technology
No new posts CFWA - Diesel Particulate Filter Malfunction Diesel Engine Technology
No new posts Diesel DPF Values: Interpretation & Meaning Diesel Engine Technology
