TDI quantity limits
Post19-12-2015, 12:07    Subject: TDI quantity limits Quote
All previous TDI engines, whether old or new, operate in a similar way regarding torque regulation.
Older engines (1Z, AFN, AHF, etc.) use mass-based measurements (mg/H, measurement block icon_cool.gif, while newer engines use torque-based measurements (Nm, measurement block 8 or various values in the extended measurement blocks).
In this process, the accelerator pedal specifies an injection amount or a desired torque, which is then limited to a value 'x' based on certain operating conditions.
- Limitation due to air mass/smoke, either based on the actual air mass or intake manifold pressure.
- Limited by the torque of the transmission (for manual transmissions), while automatic transmissions may have multiple values.
- Limitation due to maximum coupling torque (typically not utilized or a fixed value).
- Limitation due to additional safety mechanisms, e.g., caused by excessively high exhaust gas temperature (multiplication factor).
Under full throttle and a regulated load condition, the lowest limiting factor should be the transmission torque.
CJCD_Einspritzmengen_Momente.a01
 Beispielliste der Mengenbegrenzungen für erweiterte Messwertblöcke vom CJCD Motor.
 File name:  CJCD_Einspritzmengen_Momente.a01
 File size:  76 Bytes
 Downloaded:  404 times
LOG-01-2061-2071-2091-4211.CSV
 Beispiel Begrenzungen CFFB Motor mit Schaltgetriebe.
 File name:  LOG-01-2061-2071-2091-4211.CSV
 File size:  3.12 KB
 Downloaded:  434 times
Translated on 20-07-2026, 21:28.
vwSchrauber
dieselschrauber likes this.
Post22-12-2015, 13:59    Subject: TDI quantity limits Quote
Limitation due to additional protective mechanisms, e.g., due to excessively high exhaust gas temperature (multiplication factor).
Hi Rainer,
Similar protection mechanisms also exist as absolute value limiters, for example: fuel temperature (in the high-pressure pump), ambient air pressure (used to determine air density, which is a factor in cooling system design), etc.
Translated on 20-07-2026, 21:30.
Post22-12-2015, 14:10    Subject: TDI quantity limits Quote
