P0341 - Camshaft Position Sensor (G40): Implausible Signal (Solution)
Post26-04-2016, 14:55    Subject: P0341 - Camshaft Position Sensor (G40): Implausible Signal Quote
Error codes: 16725/P0341/000833 - Camshaft sensor (G40): Implausible signal
Possible Symptoms:
- MIL warning light in the cockpit is illuminated
Possible Causes:
- Faulty/Damaged wiring to the G40 camshaft sensor
- Camshaft sensor G40 faulty/damaged
- Camshaft adjusted/misaligned (Valve timing not correct)
See also:
Ratings - P0341 - Camshaft Position Sensor (G40): Implausible Signal
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake manifold flap position - implausible signal Diesel Engine Technology
No new posts Speed Signal: Unlikely or Suspicious? Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts Audi camshaft sensor - broken wire? Diesel Engine Technology
