Where is the differential pressure sensor located?
Kiborg
Post15-05-2016, 22:34    Subject: Where is the differential pressure sensor located? Quote
I would like to know the location of the differential pressure sensor in the Audi Q5 3.0 TDI.
After the engine starts, the yellow glow plug indicator light illuminates.
Okay, here's the translation:
"So, the problem description is: motorization malfunction."
After the diagnostic scan, it was determined that the differential pressure sensor is defective.
I would be very grateful for a hint as to where the "culprit" is located.
Thank you in advance.
Post15-05-2016, 22:55    Subject: Where is the differential pressure sensor located? Quote
Most likely on the injection molding machine, identifiable by one or two rubber hoses connected to it. icon_idea.gif
Here's what he looks like:
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts P244B Diesel Particulate Filter Differential Pressure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P244B - Diesel Particulate Filter - Differential Pressure... General Tips
No new posts AFN: Location of the sensor plug. Diesel Engine Technology
No new posts Where exactly is the air filter box located for a 2.5 TDI... Diesel Engine Technology
No new posts Differential pressure DPF vs. exhaust backpressure (and S... Diesel Engine Technology
No new posts Important: DPF Back Pressure Normal Values Diesel Engine Technology
