Hi Daniel,
AFAIK, the error memory only stores information about interruptions or short circuits in the relay windings, but not about any faults in the load circuit.
Using VAGCOM, you can easily check this component with the engine off using the actuator diagnostics function. In a quiet environment, you can hear the bubbling of water at the glow plugs approximately every 2 seconds. Also, with high heating power, the interior lighting should become slightly dimmer than with low power – in 95% of cases, this indicates that everything is okay. Gruß Ulf
Translated on 13-10-2026, 7:42.
