Mondeo TDCI won't start.
a4_afn
1997 Audi A4
Post17-07-2016, 21:19    Subject: Mondeo TDCI won't start. Quote
Hey
I'm having a problem and I'm stuck, and I'm hoping you can give me some tips.
It's a 2005 Mondeo 2.2TDCI.
It all started when a clip on the fuel pressure hose came loose during a drive on a country road, and the hose slipped down. Since I couldn't stop, I drove on until I reached the next breakdown area.
A roadside assistance service arrived and reinstalled the hose. Engine started, but then it was very difficult to start, and then only a black smoke cloud came out of the exhaust, and it immediately died again, and it hasn't started since.
Okay, so the car was towed away due to suspected turbo damage.
I checked the charger, but it seems to be working fine. Complete shovel wheel, no play, no oil.
Error memory read. Nothing found.
Therefore, the suspicion fell on the injectors. Since they were so eager to damage the cylinder during their demise, I decided to measure the compression first.
This is 20.20, 18, 20, which is too low.
Okay, the timing belt inspection results are normal.
So, I guess the poor compression is due to the cheap tester from eBay and a weak battery.
Engine runs normally.
What else should I check?
Who would you suspect?
I'm really at a loss.
Where could the compression be and, above all, how do the cylinders have the same values?
Was happened with the turbo hose was just a coincidence, or could it be due to faulty injectors, for example, that caused an excessively high boost pressure?
Thank you very much!
LG Alec
Post18-07-2016, 11:43    Subject: Mondeo TDCI won't start. Quote
Hi Alec,
The error is somewhat unusual, which makes it difficult to pinpoint the exact cause.
First, I would test the following:
- Are the engine timing settings correct?
- Does the engine get air, i.e. is the throttle valve or other components possibly stuck? Are the intake paths clear?
In case of insufficient fuel pressure, faulty injectors, etc., I would expect the engine control unit (ECU) to detect this and store the corresponding error codes.
Best regards, Rainer
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford Mondeo: Won't Start After Empty Tank? On-Board Diagnostics (OBD)
No new posts Ford TDCi won't start after conversion. On-Board Diagnostics (OBD)
No new posts Ford Mondeo 2.0 TDCi - where to tap into the turbo boost ... Diesel Engine Technology
No new posts Jag X-Type 2.0D Turbocharger Problem? Diesel Engine Technology
