Ibiza 6L Cupra TDI glow plug relay
silvetsups88
1994 Toyota Supra
Post28-12-2016, 11:31    Subject: Ibiza 6L Cupra TDI glow plug relay Quote
Hello everyone.
My name is Manuel, I'm 28 years old, and I come from Murau in Austria. I'm completely addicted to [something - the original text uses a slang term that needs context].
I've only recently started dealing with diesel engines because my girlfriend...
He bought an Ibiza Cupra TDI with a BPX engine.
I have to say, it's a really awesome car.
But now, let's get to the problem:
It starts relatively hard when the temperature is below 0 degrees Celsius.
Until yesterday, the preheating light wasn't working either.
I was able to get it working again by resoldering the LEDs in the dashboard.
Attempted to start again today:
The glow plug indicator light comes on for about 2 seconds, but the engine still starts poorly.
Where is the glow plug relay located in this car?
Thank you in advance.
Best regards, Manuel.
Supra MK4 760hp, Ibiza Cupra Tdi
Translated on 14-07-2026, 17:43.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post28-12-2016, 21:22    Subject: Ibiza 6L Cupra TDI glow plug relay Quote
Hello.
I would suggest looking for a dual temperature sensor (green/4-pin) in that area instead.
It is located at the cooling water outlet below the tandem pump, towards the passenger compartment.
Part No. 059919501A
A simple test would be to disconnect the sensor; in that case, the MSTG (Multi-Spark Timing Generator) will always initiate the pre-glow process.
If all the glow plugs are working correctly, the engine should start well, and in that case, the sensor would need to be replaced.
Another option would be to read the relevant data (coolant temperature, fuel temperature, and intake air temperature) using VCDS.
When the system is cold, all sensors should display approximately the same temperature values.
Mpire
Translated on 14-07-2026, 17:46.
silvetsups88
1994 Toyota Supra
Post02-01-2017, 18:11    Subject: Ibiza 6L Cupra TDI glow plug relay Quote
Hi, thanks for the reply.
There is an update.
All temperature sensors are functioning correctly.
No error is stored either.
I've now checked the glow plugs and disconnected the relay so I can manually pre-heat them.
The next day I tried again, and sure enough, it still started with difficulty.
Even though I manually preheated it for about 10 seconds at around 0 degrees Celsius.
So, it can only be a diesel-related problem now...
But what about...
Translated on 14-07-2026, 17:48.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug relay 1Z Diesel Engine Technology
No new posts Citroen C5 Glow Plug Relay Diesel Engine Technology
No new posts Seat Leon Cupra 150hp PD ARL - smoking and misfiring unde... Diesel Engine Technology
No new posts Ibiza TDI Problems: Common Issues & Solutions Diesel Engine Technology
