T5 Central Locking: 2007 Model for Sale
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
enzer200
Registered VCDS User
Post10-03-2017, 12:56    Subject: T5 Central Locking: 2007 Model for Sale Quote
Hello, I have a T5 transporter manufactured in December 2007. I would like to disable the automatic locking feature that engages after about 30 seconds, as it's inconvenient when delivering items that take 3 minutes, because the vehicle relocks every time I come back. Could you please tell me how to re-program or disable this feature? I've already searched the internet but haven't found anything suitable.
Hi and thanks,
enzer200
Translated on 18-10-2026, 3:26.
Post10-03-2017, 16:24    Subject: T5 Central Locking: 2007 Model for Sale Quote
If I'm not mistaken, it only has an automatic re-locking feature if no door has been opened.
This means you would first need to lock the car, then unlock it again without opening the door (or open a door where the door contact switch is faulty). Only then would the car be able to lock itself. However, it sounds like you're not locking the car, but you still find it locked after leaving.
What he might also have is automatic locking above 15 km/h. But even in that case, your statement doesn't fit:
annoying (... that) the car is locked again every time you come back
Please clarify when the deadline is and what you have already tried in BnSTG 09, or what coding options are displayed to you there.
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 18-10-2026, 3:28.
enzer200
Post10-03-2017, 22:40    Subject: T5 Central Locking: 2007 Model for Sale Quote
The vehicle's onboard computer only allows deactivating the central locking system above 15 km/h, which does work, but as described: remove the ignition key, exit the vehicle, close the driver's door, open the sliding door or tailgate, leave the tailgate or sliding door open, and the vehicle will still lock itself after approximately 20 seconds. This phenomenon should be disabled.
Translated on 18-10-2026, 3:29.
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Customization options for Volkswagen central locking systems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Central Locking Adjustment Options Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMW X3 2.0d: 2007 Model with AGR Seats Diesel Engine Technology
No new posts ELV Passat B6 2007 On-Board Diagnostics (OBD)
No new posts Passat 3C (2007): ELV & Engine Problems On-Board Diagnostics (OBD)
No new posts BMW E91 318d Coolant Temp Sensor N47 DDE7 2007 Diesel Engine Technology
