ECU Hardware Number: Find Yours Now!
Variweiss
2011 Volkswagen Passat
Post05-10-2017, 8:29    Subject: ECU Hardware Number: Find Yours Now! Quote
Can someone explain the difference between the engine control units (ECUs) 03L906018BF and 03L907309N, and where the corresponding properties are defined?
When using VCDS to read the data, the following information is displayed for my CFFB engine:
Part number 03L906018BF.
Hardware number 03L907309N.
Ludger
Passat 7 MKB:CFFB SG EZ 2011
Translated on 14-10-2026, 16:53.
Post05-10-2017, 9:15    Subject: ECU Hardware Number: Find Yours Now! Quote
The hardware number determines which control unit electronics were used. The VAG part number, in this case, essentially indicates which software is running on it.
The VAG part number is the relevant information for you when replacing the control unit.
Translated on 14-10-2026, 16:54.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit 1Z Diesel Engine Technology
No new posts T5 Engine Control Unit (ECU) On-Board Diagnostics (OBD)
No new posts A6 C4 TDI Engine Control Unit On-Board Diagnostics (OBD)
No new posts What engine control unit (ECU) is compatible with AHY/AXG? On-Board Diagnostics (OBD)
