I'm considering buying a VCDS version, including the hardware. Now that the HEX-V2 is out, is there a list of supported models?
I would like to purchase this item for a Polo 6R (manufactured in 2013).
Golf 7 sound, 110 kW (year 2017).
and an Audi A3 (year 2014).
would like to use,
Thank you very much.
Pit
No problem. Starting around the year 2017, you absolutely need the HEX-V2 version because the old HEX-USB+CAN hardware in the dongle doesn't have enough processing power.
Andreas
Thank you for the tips; in that case, I definitely need the HEX-V2.
I somehow overlooked the part about "all VAG models," but as they say, those who can read are always at an advantage.
