Software Update: Data Status & Changes
Karma: +1344 / -0   Thank you, like it!
Post16-12-2017, 11:19    Subject: Software Update: Data Status & Changes Quote
In the article,
This refers to the A4 8K CJCD front-wheel drive model with a manual transmission. The data version is 9977 for the software update and 9978 for a second update.
Is it known what the second update is about?
In August 2016, my 8K went from a score of 5104 to 9977.
Translated on 28-08-2026, 17:21.
Blackfrosch
dieselschrauber, guste100 and Herbert likes this.
Post19-12-2017, 22:31    Subject: Software Update: Data Status & Changes Quote
Hello Herbert,
I just took a quick look: No parameters or settings have been changed.
There are only 3 different error paths. I need to pinpoint exactly which ones they are. Perhaps this will help reduce the number of times we have to reject the MIL (Material Identification Label) for the customer.
As long as you're not plagued by erroneous entries, performing this update is as pointless as having a hole in your head.
I've now seen 9979 posts. This is an update to the update of the update.^^
"Hello"
Translated on 28-08-2026, 17:23.
Post20-12-2017, 10:38    Subject: Software Update: Data Status & Changes Quote
"Thank you!"
Translated on 28-08-2026, 17:24.
No new posts TDI Emissions Update: Software/Data Versions 1.6/2.0 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Advertisements + Software Update Diesel Engine Technology
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
