1Z Motor Spring schlecht an | Posts 16+
Go to page: Previous  1, 2
joergs
Post30-10-2003, 14:08    Subject: Quote
What is the air-fuel ratio of the injection control system at idle?
Julian
Post30-10-2003, 16:17    Subject: Quote
Then I would check the wiring harness between the battery, the generator, and the starter for clean contacts and uncorroded cables.
Does the starter motor rotate the engine above 300 RPM when you log it using VAGCOM? icon_wink.gif
nadin_tu
Post30-10-2003, 18:29    Subject: Quote
Hello everyone,
Thank you for your help.
I found the error! Unbelievable, the control unit was defective. I installed one from a Golf, and now it starts up really well again! icon_lol.gif
Sure, here's the translation:
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Sliding Door: Repair & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B, Seatbelt front does not retract properly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rust Damage: Is It Bad for Your Engine? Diesel Engine Technology
No new posts Golf 3: 1.9 TDI Engine Starting Problems Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI engine starts poorly when warm! Diesel Engine Technology
No new posts Golf III TDI Starting Problems: 1996, 1Z Engine Diesel Engine Technology
