Mercedes V6 OM642: Misfire Troubleshooting
brezelmann01
dieselschrauber likes this.
Post17-05-2019, 20:13    Subject: Mercedes V6 OM642: Misfire Troubleshooting Quote
Hello everyone,
I have a question about an OM642 engine in a friend's Viano.
The engine starts, after a somewhat longer idle time, and potentially more noticeably in combination with colder temperatures, but not on all cylinders.
With a little bit of encouragement, the rest will quickly join in.
Ansonsten völlig unauffälliger Motorlauf. Lperformance is available.
Attached is an LL (Low-Level) idle speed regulation assessment from StarDiagnose. In my opinion, it also looks completely fine, doesn't it?
What would you check next?
Mileage: 200,000 km.
Error memory is empty.
Excellent maintenance condition.
Thank you!
 File size:  379.3 KB
 Viewed:  1516 times
Translated on 05-09-2026, 6:21.
Karma: +1344 / -0   Thank you, like it!
Post18-05-2019, 7:35    Subject: Mercedes V6 OM642: Misfire Troubleshooting Quote
How about the spark plugs?
During the test (is the engine warm?), at least five cylinders are performing well, while one seems to be slightly weaker.
Translated on 05-09-2026, 6:23.
brezelmann01
Post18-05-2019, 8:32    Subject: Mercedes V6 OM642: Misfire Troubleshooting Quote
Hello!
The glow plugs have not been checked yet. Do you think a faulty glow plug could cause such effects at temperatures above 0 degrees Celsius?
During the test, the coolant temperature was 59 degrees Celsius, according to the log.
Maximum deviations can be up to ±5mg per dose, which is different from Volkswagen's standards, but that seemed acceptable to me.
Translated on 05-09-2026, 6:24.
Post18-05-2019, 12:47    Subject: Mercedes V6 OM642: Misfire Troubleshooting Quote
Perhaps he uses the glow plugs to start the engine and also lets them run for a short time afterwards.
You should observe the idle speed immediately after starting the engine. In the test you performed, the engine was already warmed up.
Translated on 05-09-2026, 6:25.
dleds
Karma: +14 / -1   Thank you, like it!
Post04-06-2019, 11:52    Subject: Mercedes V6 OM642: Misfire Troubleshooting Quote
brezelmann01 wrote:
Hello!
During the test, the coolant temperature, according to the protocol, was 59 degrees.
Maximum deviations can be +-5mg per injection, which is different from VW, but that also looked quite good to me.
Well, just because Mercedes-Benz states something doesn't mean it's necessarily true. Volkswagen also says that 1 liter of oil consumption per 1000 km is still within the acceptable range.
"Percentage-wise, relative to the target amount, approximately +/- 60% of the energy used is recovered at the crankshaft. If this were acceptable, I wonder why the injectors need to be programmed into the engine control unit."
In this case, the difference between the worst and the best result is only 15%, so I would first check the spark plugs. Especially in Sprinter and Vito vans, they are often left in for too long... it's not always easy to access them.
Translated on 05-09-2026, 6:26.
No new posts Golf 1J: Grinding Noises in All Gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MWB23: Cylinder readings -60 to -80 Diesel Engine Technology
No new posts MWB23: -60 to -80 on all cylinders, Log Upload
No new posts Audi B7 Engine: Hard Starting / Diesel in Oil Diesel Engine Technology
No new posts Differences in fill levels between the cylinders? Diesel Engine Technology
