Ratio of alternator speed to crankshaft speed with ribbed V-belt
danny
Post01-11-2003, 17:30    Subject: Ratio of alternator speed to crankshaft speed with ribbed V-belt Quote
The relationship between the alternator in a V-belt generator and one with a ribbed belt is quite different. I bought a tachometer from a newer Golf because mine was broken. Now, it's showing a value that's far too low – I'd say around 20% based on my feeling.
Does anyone have the engine speed data readily available, or the percentage difference between the two versions? Do you think it's possible to compensate for this by adjusting the potentiometer? I was considering resoldering the circuit boards, but the new one is a combined board with everything on it.
diesel.gustav
Post01-11-2003, 19:46    Subject: Ratio of alternator speed to crankshaft speed with ribbed V-belt Quote
Deleted as requested.
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts RPM decreases on the G4 AXR. Diesel Engine Technology
No new posts 320d Leistungsmangel LuMa / Ladedruck Verhältnis (GELÖST) On-Board Diagnostics (OBD)
No new posts ARL Motor: ab welcher Drehzahl beim anlassen startet er? On-Board Diagnostics (OBD)
No new posts AFN Alternator: Connect Terminal W to 120A Diesel Engine Technology
