Can the embedded lambda probe be determined optically and measurably?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post31-12-2019, 13:21    Subject: Can the embedded lambda probe be determined optically and measurably? Quote
Hello Forum,
my question doesn't quite fit here. Since it's about a lambda probe, I might actually be in the right place here, I think.
My pellet boiler seems to have a faulty lambda sensor. (Deviation from the last automatic calibration is relatively large) Can you determine the type solely based on the appearance, number of connections, color labeling of the wires, voltage values? It is supposed to be a Bosch 4.9 or NTK broadband sensor. However, I don't know if the source is reliable. Are there many different types/models?
I'm just curious - if it's difficult, I'll just have to spend the 199€ on an original probe. However, it would be frustrating if one had to spend only a fraction of it.
A negative response wouldn't be so bad at this point either.
Thank you for the responses.
Happy New Year and all the best!
Best regards, Jörg
Seat Ibiza 6L Sport ASZ EZ Mai 2003
>468000km -schweren Herzens verkauft
Seat Ibiza 6J FR CFHD EZ Mai 2015
>178000km
Fiat Ducato Kasten 2.3 Multijet
EZ 3.2011 >230000km
jörg schmidt
Post05-01-2020, 15:22    Subject: Can the embedded lambda probe be determined optically and measurably? Quote
I have now ordered the original part for 199,-€.
The post can be deleted - I think it won't provide any further insights here.
>178000km
EZ 3.2011 >230000km
Post05-01-2020, 17:40    Subject: Can the embedded lambda probe be determined optically and measurably? Quote
No new posts Help with measurement blocks for mass airflow sensor (MAF... On-Board Diagnostics (OBD)
