Hello everyone,
I'm currently having issues with the air conditioning system in my Audi A3 8L 2000 Q.
and might need some assistance from the specialists.
The goal would be to perform a stack dump analysis to reorient the pointers.
Follow-up test OK, -> 17 ->
Control unit not found.
AI is on the table (unfortunately, not a VDO)
- Pin 1, 20, and 23 on the blue connector are connected to
2.0 VDC.
- Pins 7, 9, 22, and 24 of the blue connector are connected to GND (ground).
- Pin 25, Green connector, K-line.
The OBD2 socket is on the table.
- Pins 4 and 5 of the OBD2 connector are connected to ground (GND).
- Pin 16: OBD2 is at 12.0 VDC.
- Pin 7: OBD2 connects to Pin 25 via the green connector.
What am I doing wrong?
