Which Ross-Tech diagnostic interface?
Killroy0815
Post23-03-2021, 11:18    Subject: Which Ross-Tech diagnostic interface? Quote
Which Ross-Tech diagnostic interface do I need for the following vehicle?
Sunday, March 21, 2021, 12:52:04:08740
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 20.12.0.3
Data as of: 20210220 DS322.1
Vehicle Identification Number: WMA04VUY7M9004262
License plate: RZ DF 57
Mileage: 4000. Repair order: detlef.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: UY (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 18 19 22 3C 3D 42 44 52 5F 65 69
75 A5 BB BC 810B
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block module -- Status: Error 0010.
18-Heater -- Status: OK 0000
19-Diagnostic interface -- Status: Error 0010.
22-All-wheel drive -- Status: OK 0000
3C track switch -- Status: OK 0000.
3D Special Features -- Status: Error 0010.
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
Tire pressure -- Status: OK 0000.
69 followers -- Status: OK 0000
75-Telematics -- Status: Error 0010.
A5 Front/Forward-facing camera -- Status: OK 0000
Rear left door electronics -- Status: unreachable 0100.
Rear right-side door electronics -- Status: unreachable 0100.
810B Standby/Auxiliary Heater 2 -- Status: INTERFACE HARDWARE NOT COMPATIBLE.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-DAVA)
Label file: None
Part number SW: 04L 906 056 SJ, Hardware number: 04L 907 445 P.
Part: R4 2.0l BTD H01 9970
Revision: 23203001
Encoding: 002A403C637605080000000000000000000000000000000
Operating Number: WSC 00000 000 00015
ASAM Dataset: EV_ECM20BTD03004L906056SJ 007003
ROD: n.v.
VCID: 071BDD45BE0F10BC41-8052
Vehicle/model not supported. Please purchase a current Ross-Tech diagnostic interface.
No ASAM data available: "EV_ECM20BTD03004L906056SJ" ().
2 error codes found:
31162 - ROD - Unknown error code.
- 00 [096]
Sporadically - unconfirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 2
Mileage: 3141 km
Date: 2020.12.01
Time: 16:25:52
27277 - ROD - Unknown error code.
- 00 [032]
Readiness: Not Available.
Address 02: Transmission (J217)
Label file: 09G-927-749-V2.clb
Part number SW: 09G 927 158 EH, HW: 09G 927 158.
Part: AISIN AQ8, 206 3619.
Encoding: 0000000100000000010000000000000000000000
ASAM Dataset: EV_TCMAQ450031 001001
ROD: n.v.
VCID: 7DF7BFADECD34A6C6B-8028
No ASAM data available: "EV_TCMAQ450031" ().
No error codes found.
Address 03: Brake Electronics (J104)
Label file: None
Part number SW: 2N0 907 379 E, HW: 2N0 907 379 C.
Component: ESC_base H02 0870
Serial number: 08501622200824.
Encoding: 25AA6477483DB686A449266612456D463AF724BA
ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 704031
ROD: n.v.
VCID: 38796EB98371AF44F8-806C
No ASAM data available: "EV_Brake1ESP90iBOSCHVN54X" ().
Address 08: Climate Control/Heating Unit (J255)
Label file: None
Part number SW: 7C0 907 044 BE Hardware number: 7C0 907 044 BE
Component: Climatronic H01 0602
Encoding: A07010000800100001100820500101000000000000011400200000000000
Operating Number: WSC 00000 000 00031
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: n.v.
VCID: 69DFFBFD885BC6CCB7-803C
Subsystem 1 - Part number SW: 7C0 907 049 L, HW: 7C0 907 049 L.
Part number: E857 H02 0202.
Serial number: 00003060161600260722
No ASAM data available: "EV_AirCondiBHTCVN54XT6PA" ().
Address 09: Central Electronics (J519)
Label file: . DRV\5Q0-937-08X-V2.clb
Part number SW: 5Q0 937 084 DP Hardware number: 5Q0 937 084 DP
Part: BCM MQBAB M+ H42 0411
Serial number: 01102024500304
Encoding: 0000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 021001
ROD: n.v.
VCID: 091FDB7DA81B66CC57-805C
Subsystem 1 - Part number SW: 5Q0 955 547 B HW: 5Q0 955 547 B Label file: DRV\5Q0-955-547.CLB
Part number: RLHS 052 0107.
Serial number: S4Y20M09D02H09M55S34
Encoding: 0038DD
Subsystem 2 - Part number SW: 5Q1 953 521 ED HW: 5Q1 953 569 F
Component: Steering module H24 0180.
Serial number: 0100120520200C300151
No ASAM data available: "EV_BCMMQB" ().
Address 10: Parking Assist 2 (J791) Label file: None.
Part number SW: 2N0 919 300 D, Hardware: 2N0 919 300.
Component: aFLS 16KH06 0302
Serial number: 000310350620191
Encoding: 047116D971
ASAM Dataset: EV_EPHVA2FVN54X0000 009037
ROD: n.v.
VCID: 2A5D44F14DDD0DD47E-807E
No ASAM data available: "EV_EPHVA2FVN54X0000" ().
Address 13: Distance Control (J428) Label file: 2Q0-907-572.clb
Part number SW: 2Q0 907 572 R, HW: 2Q0 907 572 B.
Part number: ACCCONTIMQB H03 0372.
Encoding: 3201404A40EF8448949C814D20308500000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: n.v.
VCID: 43830955CAB7FC9C5D-8016
No ASAM data available: "EV_ACCMRRCONTIVW376" ().
Address 15: Airbag (J234) Label file: . DRV\5Q0-959-655.clb
Part number SW: 3Q0 959 655 CL Hardware: 3Q0 959 655 CL
Part: Airbag VW21 007 0720
Revision: -------- Serial Number: 003Z1PGJAJYX
Encoding: 8800C00000000000400000CF000840000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: n.v.
VCID: 0A1DE471AD1D6DD45E-805E
Subsystem 1 - Part number: SW: ----------- HW: 454 800 508 20
Component: FrontSensor_D, part number 305 0109.
Serial number: 355005CE8021C000000O
Encoding: 2D2D2D
Subsystem 2 - Part number: SW: ----------- HW: 454 800 508 20
Component: FrontSensor_P, part number 305 0109.
Serial number: 3560065F8021C000000K
Encoding: 2D2D2D
No ASAM data available: "EV_AirbaVW21TS6VW48X" ().
Address 17: Terminal block (J285)
Label file: None
Part number SW: 7C0 920 741 D, HW: 7C0 920 741 D.
Component: COMBINATION INSTRUMENT 202 8400
Encoding: 07A41188ECAC0008008A6A0F5401000800600000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: n.v.
VCID: 2547B7CD24C322AC53-8070
No ASAM data available: "EV_DashBoardVDDMQBAB" ().
"1 error found:"
9456681 - ROD - Unknown error code.
- 00 [008]
Sporadically - confirmed - checked since last deletion.
Error priority: 6
Error frequency: 5
Mileage: 2562 km
Date: 2020.11.16
Time: 13:25:09
Address 18: Auxiliary heater (J364)
Label file: None
Part number SW: 5WA 963 272 A, Hardware: 5WA 963 272 A.
Part number: STH-VW37x 006 0010
Serial number: 000000000000033
Encoding: 7523222054121512DCE519
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
ROD: n.v.
VCID: 4B932175E2E734DCA5-801E
No ASAM data available: "EV_AuxilHeateWOSVW38X" ().
"1 error found:"
0036 - ROD - Unknown error code.
- 00 [096]
Address 19: Diagnostic interface (J533)
Label file: . DRV\3Q0-907-530-V1.clb
Part number SW: 3Q0 907 530 AG, HW: 3Q0 907 530 C.
Part: GW MQB High 442 4424
Revision: -------- Serial Number: 0001099247
Encoding: 030100544F05730000000000000F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: n.v.
VCID: 74E19A89DF990B2414-8020
Part number: 4-00-05-00-04
Subsystem 2 - Part number SW: 5G0 959 442 AB HW: 5G0 959 442 AB Label file: DRV\3C8-959-537.CLB
Part: E221__MFL-MD9 H18 0052
Serial number: 39200000975670080164.
Encoding: 2EFFFF
Subsystem 3 - Part number SW: 2N0 915 181 A, HW: 2N0 915 181 A.
Part: J367-BDMConti H03 1051
Serial number: 75885102002003200173.
No ASAM data available: "EV_GatewNF" ().
131699 - ROD - Unknown error code.
- 00 [008]
Error priority: 2
Error frequency: 1
Lost Count: 122
Mileage: 4199 km
Date: 2021.02.28
Time: 16:23:36
8531970 - ROD - Unknown error code.
- 00 [008]
Error priority: 7
Error frequency: 2
Lost Count: 109
Date: 2000.00.00
Time: 00:00:00
Address 22: All-wheel drive (J492) Label file: DRV\0CQ-907-554.clb
Part number SW: 0CQ 907 554 N, HW: 0CQ 525 130 B.
Part: Haldex 4Motion H60 7322
Serial number: HA1-00011.11.19.
Encoding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004014
ROD: n.v.
VCID: 50A936190BC11704D0-8004
No ASAM data available: "EV_AllWheelContrHA1VW37X" ().
Address 3C: Lane Change (J1086)
Label file: . DRV\5Q0-907-686.clb
Part number SW: 5Q0 907 686 C, Hardware: 5Q0 907 686 C.
Component: HRE_Master H12 0081
Serial number: 0549598373.
Encoding: 02012103
ASAM Dataset: EV_HREntryHella 001028
ROD: n.v.
VCID: 3D777FADAC538A6C2B-8068
No ASAM data available: "EV_HREntryHella" ().
Address 3D: Special functions (J60http://shop.dieselschrauber.org/en) Label file: None.
Part number SW: 2N0 907 427 P, HW: 2N0 907 427 H.
Part: KFG H24 0306
Serial number: GB24203537331.
Encoding: 00002000000000200200000820F0000000000000
ASAM Dataset: EV_SpeciFunctFlextVN54X 007029
ROD: n.v.
Subsystem 1 - Part number SW: 2N0 915 181 B, HW: 2N0 915 181 B.
Serial number: 75885002002008130058.
No ASAM data available: "EV_SpeciFunctFlextVN54X" ().
3 error codes found:
393498 - ROD - Unknown error code.
- 00 [008]
Error priority: 6
Error frequency: 20.
Lost Count: 139
Mileage: 4391 km
Date: 2021.03.20
Time: 14:36:35
394266 - ROD - Unknown error code.
- 00 [008]
Error priority: 6
Error frequency: 5
Lost Count: 139
Mileage: 4391 km
Date: 2000.00.00
Time: 00:00:00
394778 - ROD - Unknown error code.
- 00 [008]
Error priority: 6
Error frequency: 1
Lost Count: 139
Mileage: 4391 km
Date: 2021.03.20
Time: 14:36:41
Address 42: Door electronics. Driver (J386) Label file: .5QX-959-X93-42.clb
Part number SW: 5Q4 959 593 K, HW: 5Q4 959 593 K.
Part number: TSG FS 007 0485.
Serial number: 0000418749743
Encoding: 00300B20D000020100001000
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: n.v.
VCID: 4D972F6D1CF33AECBB-8018
No ASAM data available: "EV_DCU2DriveSideMAXHCONT" ().
Address 44: Steering Assist (J500)
Label file: None
Part number SW: 2N0 909 144 J, HW: 2N0 909 144 E.
Part number: EPS_MQB_ZFLS 732 7031
Encoding: 1107
ASAM Dataset: EV_SteerAssisMNB 002009
ROD: n.v.
VCID: 3567678D9463522CE3-8060
No ASAM data available: "EV_SteerAssisMNB" ().
Address 52: Door opener (or electric door release). Front passenger seat. (J387) Label file: .5QX-959-X92-52.clb
Part number SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Part number: TSG BFS 007 0485.
Serial number: 0000419430906
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: n.v.
VCID: 4C912269E7E933E4AC-8018
No ASAM data available: "EV_DCU2PasseSideMAXHCONT" ().
Address 5F: Information selection. I (J794) Label file: None.
Part number SW: 3G5 035 820 B, HW: 3G5 035 820 B.
Component: MU-O-ND-EU H22 0270
Serial number: VWZAZ2X0616093.
Encoding: 8540000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: n.v.
VCID: 2343A9D52AF7DC9C3D-8076
No ASAM data available: "EV_MUOIMQB" ().
Address 65: Tire Pressure (J502) Label file: 3AA-907-273.clb
Part number SW: 5Q0 907 273 D, HW: 5Q0 907 273.
Component: RDKBERU30 H05 0010
Serial number: 30000000453113.
ASAM Dataset: EV_RDKBERU30 006001
ROD: n.v.
VCID: 3665608189655934EA-8062
No ASAM data available: "EV_RDKBERU30" ().
Address 69: Trailer (J345) Label file: None
Part number SW: 7C0 907 383 Hardware number: 7C0 907 383
Part: Trailer H10 0055
Serial number: 000000000005546
Encoding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: n.v.
VCID: 68D9FEF99351FFC4A8-803C
No ASAM data available: "EV_TrailFunctGener3Hella" ().
Address 75: Telematics (J949) Label file: None.
Part number SW: 5WA 035 284 B, Hardware number: 5WA 035 284 B.
Part: OCUGen3High H20 0035
Serial number: 0000000007VIGT0
Encoding: 0654200019E898209005460160002607
ASAM Dataset: EV_OCUGen3High 003005
ROD: n.v.
VCID: 4587174DC483C2AC73-8010
No ASAM data available: "EV_OCUGen3High" ().
"1 error found:"
1644017 - ROD - Unknown error code.
- 00 [008]
Error priority: 6
Error frequency: 46.
Lost Count: 40
Mileage: 4069 km
Date: 2021.02.07
Time: 03:45:42
Address A5: Front/Forefield camera (R242)
Label file: . DRV\3Q0-980-65X-A5.clb
Part number SW: 3Q0 980 654 S, HW: 3Q0 980 654 A.
Part: MQB_B_MFK H14 0920
Serial number: 28082012P20290.
Encoding: 0105040300000401002213558146450092000E20002000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: n.v.
VCID: 479B1D45FE8FD0BC81-8012
No ASAM data available: "EV_MFKBoschMQBB" ().
Address BB: Rear left door electronics.
unavailable
Address BC: Rear right door electronics.
unavailable
Address 810B: Standby/Auxiliary Heater 2.
Interface hardware is not compatible.
End----------------------------(Duration: 04:54)-----------------------------
Thank you in advance.
dieselschrauber likes this.
Post23-03-2021, 11:57    Subject: Re: Which Ross-Tech diagnostic interface? Quote
Why not just state directly what type of vehicle it is?
According to the chassis number, it is a MAN, type UY = TGE.
Since the vehicle has a special control unit installed, it's likely a MAN / VW Crafter ambulance or similar. Correct?
The model year "9" would normally indicate the year 2009 for a Volkswagen vehicle. However, considering the engine control unit (ECU), it should actually be a newer vehicle. "It's likely that MAN uses a different system for translating model year numbers compared to VW. (2019 might be a more accurate year)."
As far as I know, we haven't covered anything about diagnostics for MAN vehicles here yet. Perhaps Rainer can contribute something to this.
Killroy0815
Post23-03-2021, 12:17    Subject: Which Ross-Tech diagnostic interface? Quote
Is it a MAN 4x4 camper?
Even MAN itself is having trouble with these regulations.
Otherwise, I will send him somewhere else.
Post23-03-2021, 12:36    Subject: Which Ross-Tech diagnostic interface? Quote
That specific vehicle doesn't really tell me much.
There are 2 things to consider:
- The diagnostic hardware must be accurate.
- Software support must be available.
Due to.
I recommend that you first update your VCDS version (customer account, or software downloads information).
Then you can see which control units have available information. For those following along: VCDS is constantly being expanded, and VCDS software updates are free of charge for our customers.
Regarding diagnostic hardware, I recommend the following for workshops that already have a HEX-USB+CAN:
https://shop.dieselschrauber.org/en/vcds-interface-upgrade-p-342.php
For DIY enthusiasts, the HEX-V2 is also available with a limited number of vehicle licenses. Of course, it is also available without limits for workshops (provided they do not already own a HEX-USB+CAN).
https://shop.dieselschrauber.org/en/vcds-hex-v2-p-329.php
If someone owns a HEX-V2 or HEX-NET device (original, regardless of location) with a limited number of vehicles, it can be upgraded later to support more vehicles or an unlimited number of vehicles (which is the workshop version).
https://shop.dieselschrauber.org/en/vcds-lizenz-upgrade-p-343.php
No new posts HEX-NET: Reset to factory settings On-Board Diagnostics (OBD)
No new posts Ross-Tech USB interface not found! On-Board Diagnostics (OBD)
No new posts Ross Tech V2 NET: Won't Stay in Slot? On-Board Diagnostics (OBD)
No new posts Ross-Tech 9082 with DS-Hex Interface? On-Board Diagnostics (OBD)
