MrMcFly79 Blaumann
06-11-2021, 14:03 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
Hi again, it's me with my new care recipient.
So, I measured the compression yesterday...
1 cylinder, 25 bar.
2 cylinders, 28 bar.
3 cylinders, 28 bar.
According to the target values discussed in this forum, it's still absolutely within the acceptable range.
I only found the information for the 1.9 version, but it should be comparable.
New condition: 25-31 bar.
Seals at 19 bar.
Maximum cylinder pressure difference: 5 bar.
... are really extremely good/bad?!
I don't feel comfortable with the pressure of 25 bar.
Here are some endoscopic images; unfortunately, the camera isn't the best. I've marked two areas: one is a horizontal "scratch," and the other has some strange vertical lines... what do you think about these?
Tobi.
Oh yeah, mileage: 220,000 km.
| Description: |
| File size: |
29.19 KB |
| Viewed: |
1489 times |
| Description: |
| File size: |
47.53 KB |
| Viewed: |
1541 times |
| Description: |
| File size: |
23.4 KB |
| Viewed: |
1487 times |
| Description: |
| File size: |
26.39 KB |
| Viewed: |
1488 times |
Translated on 19-08-2026, 11:20.
Joined: 04/12/2002 Posts: 18098 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
07-11-2021, 20:04 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
The "horizontal scratch" is likely the turning point of a piston ring.
The vertical scratches are usually caused by foreign particles (e.g., grains of sand) that get between the piston and the cylinder wall.
Overall, I can no longer detect any signs of wear, and I expected to see much more mileage based on the pictures.
It might also be the image quality that makes it look like that.
If the compression is bad, you'll notice it first on the oil cap; it should still be bouncing off the open oil filler opening when idling and not flying against the hood.  Just take a look; there shouldn't be any significant pressure building up with the cap on.
Translated on 19-08-2026, 11:22.
Profile PM WWW Garage |
MrMcFly79 Blaumann
dieselschrauber likes this. |
13-11-2021, 17:55 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
No, no bruises, he's just dancing a little bit. Never mind, I'm driving the car now... don't worry too much  .
Translated on 19-08-2026, 11:24.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1508 Karma: +643 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
22-11-2021, 6:59 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
Hi there!
As I mentioned before, continue driving. Even a small amount of oil residue somewhere on the valves can cause such a compression loss, but as long as it's running smoothly, keep going.
Profile PM Garage |
MrMcFly79 Blaumann
22-11-2021, 22:14 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
Today, after changing the oil, I checked the filter...  When you run a magnetic rod through it, a small amount of metallic debris remains attached...
I'm curious to see how long it will last.
Translated on 19-08-2026, 11:25.
MrMcFly79 Blaumann
25-11-2021, 12:23 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
Yesterday, I rinsed the filter with brake cleaner and ran it through the measuring cup using a magnet.
| Description: |
| File size: |
7.02 MB |
| Viewed: |
389 times |
MrMcFly79 Blaumann
25-11-2021, 12:25 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
So, the camshafts are quite worn, and I suspect that's the cause of the problem.
| Description: |
| File size: |
158.65 KB |
| Viewed: |
386 times |
Translated on 19-08-2026, 11:26.
02-12-2021, 22:09 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
It could also be coming from the hydraulic lifters, which are the counterparts to the camshaft lobes. Try pushing a valve down with a wooden stick and wiping over it.
Not that he looks like the one in the picture.
| Description: |
| File size: |
130.46 KB |
| Viewed: |
343 times |
MrMcFly79 Blaumann
04-12-2021, 11:03 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
Yes, it could be a good combination :-//
I was very surprised to see how the camshafts looked after 220,000 km. I checked the vehicle's history and it seems they always used a 0W30 oil... Was that only available with the previous long-life standard, which had a lower HTHS value? The oil change intervals were typically around 15,000 - 17,500 km.
Tobi.
Translated on 19-08-2026, 11:27.
MrMcFly79 Blaumann
19-05-2022, 17:24 Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes |
So, I started a restoration project that takes into account the value of time. The camshaft and lifters were actually worn out; the camshaft had wear of 1.5 to 2.0 mm compared to a new one, and some of the lifters were already visibly compressed and rough.
"Because I had a very high oil consumption, I also wanted to reseal the PD elements. However, it turned out that the seats were already quite worn. So, I got a used head, removed the old one, and found cracks in every injector bore. The head gasket was also leaking in two places between the cylinders."
Based on the endoscopic images, the cylinder walls appeared smooth, which I suspect was due to the sprite injection.
I simply got a wire brush and went over it, the result you can see in the pictures, I'm curious to see how long it lasts  .
| Description: |
| File size: |
4.27 MB |
| Viewed: |
314 times |
| Description: |
| File size: |
3.38 MB |
| Viewed: |
271 times |
| Description: |
| File size: |
2.7 MB |
| Viewed: |
290 times |
Translated on 19-08-2026, 11:29.
