2.0 TDI BPW Engine Failure: Causes & Fixes
MrMcFly79
Post06-11-2021, 14:03    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
Hi again, it's me with my new care recipient.
So, I measured the compression yesterday...
1 cylinder, 25 bar.
2 cylinders, 28 bar.
3 cylinders, 28 bar.
According to the target values discussed in this forum, it's still absolutely within the acceptable range.
I only found the information for the 1.9 version, but it should be comparable.
New condition: 25-31 bar.
Seals at 19 bar.
Maximum cylinder pressure difference: 5 bar.
... are really extremely good/bad?!
I don't feel comfortable with the pressure of 25 bar.
Here are some endoscopic images; unfortunately, the camera isn't the best. I've marked two areas: one is a horizontal "scratch," and the other has some strange vertical lines... what do you think about these?
Tobi.
Oh yeah, mileage: 220,000 km.
 File size:  29.19 KB
 Viewed:  1498 times
 File size:  47.53 KB
 Viewed:  1550 times
 File size:  23.4 KB
 Viewed:  1496 times
 File size:  26.39 KB
 Viewed:  1497 times
Translated on 19-08-2026, 11:20.
Post07-11-2021, 20:04    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
The "horizontal scratch" is likely the turning point of a piston ring.
The vertical scratches are usually caused by foreign particles (e.g., grains of sand) that get between the piston and the cylinder wall.
Overall, I can no longer detect any signs of wear, and I expected to see much more mileage based on the pictures.
It might also be the image quality that makes it look like that.
If the compression is bad, you'll notice it first on the oil cap; it should still be bouncing off the open oil filler opening when idling and not flying against the hood. icon_wink.gif Just take a look; there shouldn't be any significant pressure building up with the cap on.
Translated on 19-08-2026, 11:22.
MrMcFly79
dieselschrauber likes this.
Post13-11-2021, 17:55    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
No, no bruises, he's just dancing a little bit. Never mind, I'm driving the car now... don't worry too much icon_cool.gif.
Translated on 19-08-2026, 11:24.
Post22-11-2021, 6:59    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
Hi there!
As I mentioned before, continue driving. Even a small amount of oil residue somewhere on the valves can cause such a compression loss, but as long as it's running smoothly, keep going.
MrMcFly79
Post22-11-2021, 22:14    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
Today, after changing the oil, I checked the filter... icon_confused.gif When you run a magnetic rod through it, a small amount of metallic debris remains attached...
Translated on 19-08-2026, 11:25.
MrMcFly79
Post25-11-2021, 12:23    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
Yesterday, I rinsed the filter with brake cleaner and ran it through the measuring cup using a magnet.
 File size:  7.02 MB
 Viewed:  391 times
MrMcFly79
Post25-11-2021, 12:25    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
So, the camshafts are quite worn, and I suspect that's the cause of the problem.
 File size:  158.65 KB
 Viewed:  389 times
Translated on 19-08-2026, 11:26.
Post02-12-2021, 22:09    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
It could also be coming from the hydraulic lifters, which are the counterparts to the camshaft lobes. Try pushing a valve down with a wooden stick and wiping over it.
 File size:  130.46 KB
 Viewed:  344 times
MrMcFly79
Post04-12-2021, 11:03    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
Yes, it could be a good combination :-//
I was very surprised to see how the camshafts looked after 220,000 km. I checked the vehicle's history and it seems they always used a 0W30 oil... Was that only available with the previous long-life standard, which had a lower HTHS value? The oil change intervals were typically around 15,000 - 17,500 km.
Tobi.
Translated on 19-08-2026, 11:27.
MrMcFly79
Post19-05-2022, 17:24    Subject: 2.0 TDI BPW Engine Failure: Causes & Fixes Quote
So, I started a restoration project that takes into account the value of time. The camshaft and lifters were actually worn out; the camshaft had wear of 1.5 to 2.0 mm compared to a new one, and some of the lifters were already visibly compressed and rough.
"Because I had a very high oil consumption, I also wanted to reseal the PD elements. However, it turned out that the seats were already quite worn. So, I got a used head, removed the old one, and found cracks in every injector bore. The head gasket was also leaking in two places between the cylinders."
Based on the endoscopic images, the cylinder walls appeared smooth, which I suspect was due to the sprite injection.
I simply got a wire brush and went over it, the result you can see in the pictures, I'm curious to see how long it lasts icon_biggrin.gif.
 File size:  4.27 MB
 Viewed:  317 times
 File size:  3.38 MB
 Viewed:  272 times
 File size:  2.7 MB
 Viewed:  292 times
Translated on 19-08-2026, 11:29.
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP Failure: Troubleshooting & Solutions Diesel Engine Technology
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
