Florian320
2004 Audi Cabriolet Premium Support
16-03-2022, 12:53 Subject: Golf VII: Disable Pace Car Lights (Coding) |
Hi!
I received a request to remove the flashing light feature from a Volkswagen Golf VII, as the TÜV (German technical inspection authority) does not approve of it.
I am aware that for lamps 16 and 17, I need to select the "L/R Bright Phase" option for light function A.
I'm not familiar with the other settings or their original values, and I don't know where to find them.
Does anyone know of a resource that explains how different settings should be configured (e.g., light function B, dimming value AB/CD, light control HD AB, light function C and D, dimming direction CD)?
Florian.
Translated on 08-09-2026, 4:42.
Profile PM Garage |
Ich_Can_nix Profi-Schrauber
dieselschrauber likes this. |
16-03-2022, 14:33 Subject: Golf VII: Disable Pace Car Lights (Coding) |
Hello Florian,
If it truly involves decoding, you can compare these values.
Then it will be alright again.
IDE08788-ENG122204-Dynamic Blink Modes-ZV_Blinking_on, active, 4 -> Not active.
IDE08788-ENG122203-Dynamic Blink Modes-ZV_Blinking_on, active, 4 -> Not active.
ENG116952-ENG116183-Light16BLK SLB35BLK SL KC9-Light function C 16, Active blinking function has an associated bit set to 1 in pa_dynamic_blinking, 16 -> Not active.
ENG116952-ENG116185-Light16BLK SLB35BLK SL KC9-Dimming value CD 16,100 ,16 -> 0
ENG116952-ENG116187-Light16BLK SLB35BLK SL KC9-Light function E 16, Right turn signal, Bright phase, 16 -> Not active.
IDE05145-ENG116189-Light Configuration-Dimming Value EF 16.0, 560
IDE05145-ENG116190-Lighting Configuration-Dimming Direction EF 16, minimize, 560 -> Maximize.
ENG116953-ENG116202-Light17TFL R BLK SRB3TFL R BLK SR KC3-Light function C 17, The active flashing function has an associated bit set to 1 in pa_dynamisch_blinken, 16 -> Not active.
ENG116953-ENG116204-Light17TFL R BLK SRB3TFL R BLK SR KC3-Dimming value CD 17.100, 16 -> 0
ENG116953-ENG116206-Light17TFL R BLK SRB3TFL R BLK SR KC3-Light Function E 17, Left Turn Signal, Bright Phase, 16 -> Not Active.
ENG116953-ENG116208-Light17TFL R BLK SRB3TFL R BLK SR KC3-Dimming value EF 17.0, 16.0
IDE05145-ENG116209-Lighting Configuration-Dimming Direction EF 17, minimize, 560 -> Maximize.
Michael.
Translated on 08-09-2026, 4:46.
Herbert Profi-Schrauber
16-03-2022, 14:38 Subject: Golf VII: Disable Pace Car Lights (Coding) |
"That's just a gimmick that people buy to fancy up their car. Maybe the customer unknowingly bought the car used like that."
Then go back to the seller. Otherwise, contact the creator of this light organ.
Herbert. Horch A4 8K CJCD
Translated on 08-09-2026, 4:50.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
Herbert likes this. |
16-03-2022, 21:47 Subject: Golf VII: Disable Pace Car Lights (Coding) |
Please request the CodingLog.CSV and AdpLog.CSV files from Verbasteler.
Profile PM WWW Garage |
Florian320
17-03-2022, 7:50 Subject: Golf VII: Disable Pace Car Lights (Coding) |
Good morning and thank you very much!
The car was, of course, acquired in that manner.
The customer has now informed me that the StartStop function has been deactivated using Carly, and he would like it to be reactivated. Can you tell me which coding is required for this?
I will definitely let you know if it works out.
Florian.
Translated on 08-09-2026, 4:51.
Profile PM Garage |
Florian320
17-03-2022, 17:13 Subject: Golf VII: Disable Pace Car Lights (Coding) |
Okay, I have good news. There was a communication misunderstanding with the customer: it turned out that the issue was only with the "pace car" flashing when using the hazard lights, which is relatively easy to reprogram. The normal turn signal was still activated when turning.
I also immediately activated the start-stop system, which wasn't a major issue either.
Thank you for your help!
Translated on 08-09-2026, 4:52.
Profile PM Garage |
18-03-2022, 17:10 Subject: Golf VII: Disable Pace Car Lights (Coding) |
Translating... |
[Translating...]  |
