I am currently reading the latest developments with great interest.
I own a vehicle with a BKS engine and recently installed a new DPF (including a new differential pressure sensor).
I don't see any way to reset the oil ash value. Yes, there is a "Long Adaptation" channel 81 in VCDS (PCI 21.9.0) where you can reset learning values, but in module 104-1, the oil ash volume value remains at 0.83 – the DPF is new, and this value needs to be set to 0 somewhere...
The temperatures before the turbocharger and before the particulate filter are okay, the differential pressure is plausible, and a recorded test drive also shows no unusually high peaks. I'm also seeing 899 degrees; I think all BKS systems with this control unit display this value - the sensor doesn't physically exist, but it apparently isn't masked.
I was able to perform the service regeneration without any problems. During the long adaptation process, I reset the DPF learning values (by writing "0001").
There is no "Channel 12" that sets the oil ash volume to "0.0" (or I haven't found one).
The temperatures before the turbo and before the particulate filter are okay, the differential pressure is plausible, and a recorded test drive also shows no unusually high peaks. I also see 899 degrees on my system; I think all BKS systems with this control unit display this value - the sensor doesn't physically exist, apparently it isn't masked.
I was able to perform a service regeneration without any problems. During the long adaptation process, I reset the DPF learning values (by writing "0001").
There is no "Channel 12" that sets the oil ash volume to "0.0" (or I cannot find one).
However, the volume of ash produced by the oil is adjustable. Otherwise, it would never be possible to meaningfully replace or clean a DPF.
Please ensure that your email address is the same in both the shop and the forum so that your customer status is clearly visible.
...right - there must be a way to adjust or reset it somewhere.
I'm not even sure if I have access to the shop.
I hadn't realized the extent of the interconnectedness before.
I created an account - I bought my Hex2 years ago in a 10ViN version (elsewhere) - I hope that I won't feel "unwelcome" here .
