Disabling Transport Mode with Security Access (Solution)
Herbert and E30_V8 likes this.
Post25-05-2023, 12:43    Subject: Disabling Transport Mode with Security Access Quote
Deactivating Transport Mode with Security Access.
Certain newer vehicles require a login via Security Access (16) before the transport mode can be deactivated.
VCDS
CAN Gateway [19] > Security Access 20103 > IDE00002 - Transport mode.
Ratings - Disabling Transport Mode with Security Access
No new posts Deaktivierung AGR Diesel Engine Technology
This topic is locked, you cannot edit or reply. AGR Deactivation: Where to Find Setting? On-Board Diagnostics (OBD)
No new posts AGR Valve: Engine Stall When Deactivated Diesel Engine Technology
