Jerky movement and limp mode on a 2.5 TDI
Andreas_M
Post06-08-2023, 10:43    Subject: Jerky movement and limp mode on a 2.5 TDI Quote
"I'm experiencing a problem with my T5 van, which has a 2.5L AXD engine. When I accelerate gently, around 1800 RPM, there's a noticeable jerkiness. The cause seems to be that the turbocharger is building boost abruptly (which is quite audible)."
I also have the problem that it repeatedly goes into limp mode during longer journeys. The error code stored is "boost pressure exceeds limit."
My suspicion was that there was a leak somewhere in the exhaust system, as I could repeatedly hear noises, especially when towing. However, I haven't been able to find any leaks anywhere.
Die Ladeluftstrecke habe ich bereits mit Nebel auf Dichtigkeit geprüft, ebenso das Unterdrucksystem. Unter Druck kann ich die Ladeluftstrecke leider nicht prüfen, da mir die Mittel dazu fehlen. Ölige Stellen sind aber nirgends zu sehen. VTG is common.
So far, I've already replaced quite a few things.
N75
AGR
Boost pressure sensor.
tandem pump
Translated on 20-07-2026, 23:51.
Post06-08-2023, 18:28    Subject: Jerky movement and limp mode on a 2.5 TDI Quote
Hi Andreas,
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Translated on 20-07-2026, 23:52.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts LOG AFN-Emergency Mode Upload
This topic is locked, you cannot edit or reply. Emergency Mode at 160 Diesel Engine Technology
No new posts T5, 2,5 Emergency mode BPC Upload
No new posts T5 Emergency: 2.5 BPC Mode Activated Diesel Engine Technology
