Herbert Profi-Schrauber
dieselschrauber likes this. |
23-05-2021, 5:27 Subject: |
A4 8K, CJCD, Mileage approximately 140 Tkm, Freshly regenerated:
Differential Pressure:
- 2 hPa at 0 min-1, Offset 1 hPa
- 26 hPa at 1500 min-1 (Full throttle, DPF 276 °C, air mass flow 56 g/s, boost pressure 1755 hPa)
- 150 hPa at 4000 min-1 (Full throttle, DPF 488 °C, air mass flow 152 g/s, boost pressure 2330 hPa)
Volume: 0.09 l (39.5g) with a limit of 0.175 l.
Herbert Horch A4 8K CJCD
15-09-2023, 18:09 Subject: |
A4 8K, CJCD, Odometer: 180 Tkm, Freshly Regenerated:
at 5 hPa, offset 1 hPa
at 3 full-throttle runs in 4th, 5th, and 4th gear Gang:
- around 30 hPa at 1500 min-1;
- around 190 hPa at 4000 min-1.
Volume: 0.12 l (53.1 g) with a limit of 0.175 l.
05-11-2024, 14:23 Subject: |
A4 8K, Mileage: 199700 km, Recently refurbished:
Idle 9 hPa (after 3 measurements), Offset 0hPa
at 3 full throttle runs: 5th gear:
- around 190 - 200 hPa at 4000 min-1.
Consumed 56.6 g (0.14 l) at a limit of 0.175 l.
After the previous service regeneration trip, the soot mass values (measured and calculated) are finally identical, with no decimal places. Previously, the difference was 8 g (calculated > measured). Due to the high calculated value, regenerations had become more frequent.
Joined: 04/12/2002 Posts: 18138 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
14-10-2025, 11:01 Subject: |
Quote: | VW T5
MKB CAAC
150.000km
Last regeneration at 130km
max. Differential pressure at 3600 rpm: 195 hPa |
Profile PM WWW Garage |
