Intermittent fault: Engine control unit and pump-nozzle valve issue
bert.horstkemper
Post05-09-2023, 10:03    Subject: Intermittent fault: Engine control unit and pump-nozzle valve issue Quote
Hello diesel mechanics,
"I've been having a problem with my A6 4B with a 1.9 TDI AVF engine for almost two years."
6-speed manual transmission, and I'm stuck. (VCDS log below).
The vehicle will be driven five days a week, with two trips of 30 km each day, and on weekends.
Sometimes it's like this, sometimes like that.
Occasionally, and in a way that is not reproducible, the engine check light comes on, and the engine...
shudders. Sometimes the engine stalls, but it can be restarted immediately.
Sometimes it doesn't turn on, but it usually needs to be restarted.
The procedure of restarting sometimes works on the first try, but sometimes it doesn't.
Only after 5 to 10 attempts, or after waiting for a few minutes.
So far, I have replaced the jumper wires to the PD elements and the tandem...
The pump has been replaced with a new part. The diesel and air filters are also new.
The actuator diagnostics and the inspection of the VTG (Variable Transmission Gear) revealed no errors.
However, the turbocharger forces a certain amount of oil into the airflow.
A long time ago, I installed a Steinbauer P-box, according to the manufacturer's specifications.
It increases the value of the item by 20%.
Hopefully, I haven't forgotten any essential information about the vehicle.
Has anyone else experienced similar problems and been able to resolve them?
I am grateful for any help.
Best regards, Bert.
bert.horstkemper likes this.
Post05-09-2023, 10:08    Subject: Intermittent fault: Engine control unit and pump-nozzle valve issue Quote
Relay 109 is a strong candidate. The relay may also have a different name; it's best to obtain a wiring diagram for your vehicle. It provides power to the engine control unit (ECU). You can find countless posts on this topic in this forum.
Also, also make sure that the plugs and cables on your device are in good condition.
If you have an old fuse box on the battery, check and replace it as well. It can cause such disturbances in the vehicle's electrical system that the ECU resets.
bert.horstkemper
Post05-09-2023, 19:01    Subject: Intermittent fault: Engine control unit and pump-nozzle valve issue Quote
Hello Rainer,
The relay is already a good clue.
I will exchange and report.
Best regards, Bert.
bert.horstkemper
Post07-09-2023, 14:20    Subject: Intermittent fault: Engine control unit and pump-nozzle valve issue Quote
I now have a new relay 109, but I have no idea where it is.
that is built-in. Is that thing in the box inside the water tank?
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
dieselschrauber and bert.horstkemper likes this.
Post08-09-2023, 5:29    Subject: Intermittent fault: Engine control unit and pump-nozzle valve issue Quote
It should be located in the water tank. From the driver's perspective.
It can be tricky to get the lid open icon_rolleyes.gif.
Sure, here's the translation:
"Note:"
It's possible that on the Passat, it's not labeled "109," but rather has a different designation. If you bought a "109" model without any specific information, it's possible that it might not fit icon_evil.gif.
I know from the Passat 3BG that there's a double contact relay there, and it's labeled with the number 219.
Similarly, I had to replace the starter on my Audi A4 B5 with the AJM engine; it would also occasionally fail to start, but instead of not starting at all, it would take a delayed start (around 6-7 seconds). Since then, no problems whatsoever. icon_smile_thumb_up.gif
bert.horstkemper
dieselschrauber likes this.
Post17-09-2023, 20:12    Subject: Intermittent fault: Engine control unit and pump-nozzle valve issue Quote
...so, I replaced the relay 219. Item number 109 is not available in the online store.
Error codes read and cleared.
The old relay actually looks to be in good condition on the inside. Let's just wait and see...
Gremlin
Avatar-Gremlin
Post20-09-2023, 8:13    Subject: Intermittent fault: Engine control unit and pump-nozzle valve issue Quote
Most of the time, it's not the relay itself that is worn out, but rather that the solder joints have hairline cracks. icon_wink.gif
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pump-nozzle Diesel Engine Technology
No new posts AJM Injector Pump GRA Calibration Diesel Engine Technology
No new posts Pump Nozzle Problem AXR - Common Issue? Diesel Engine Technology
No new posts ESP Error: Troubleshooting & Solutions On-Board Diagnostics (OBD)
