HTHS Oil for VE-TDI: <3.4 mPa.s
Sepp
Post17-11-2003, 9:41    Subject: HTHS Oil for VE-TDI: <3.4 mPa.s Quote
'Does anyone have experience using 0W-30 oil that meets the VW specification 50600 or 50601 in TDI engines with a distributor injection pump? A particular feature of these oils is their reduced high-temperature viscosity (HTHS = High Temperature High Shear) of < 3.4 milliPascal-seconds [mPa.s]. As far as I know, these oils are only specified for PD-TDI engines.'
Sepp.
Translated on 11-10-2026, 7:41.
Gremlin
Post17-11-2003, 13:01    Subject: HTHS Oil for VE-TDI: <3.4 mPa.s Quote
Let me put it this way:
My ALH absolutely requires 50600.
If your question concerns older generations (i.e., before the 'longlife' era), opinions vary greatly. -> Use the search function.
CU Gremlin.
Translated on 11-10-2026, 7:42.
AFB Biene
Post17-11-2003, 15:10    Subject: HTHS Oil for VE-TDI: <3.4 mPa.s Quote
In my 1998 AFB, it has been installed from the beginning! I would almost say that the oil consumption of my engine is hardly measurable!! Luckily for me!! With 192,000 km! icon_eek.gif
Sepp
Post18-11-2003, 8:57    Subject: HTHS Oil: What Makes It Longlife? Quote
Thank you for your responses.
So, does the VW/Audi Longlife approval simultaneously mandate the use of HTHS < 3.4 mPa.s oils according to specifications 50600/601?
This means that these engines are designed to work with these specific oils, and should not be operated with conventional oils (with an HTHS viscosity greater than 3.5 mPa.s).
Greetings.
Sepp.
Translated on 11-10-2026, 7:43.
Thomas K.
Post18-11-2003, 9:42    Subject: HTHS Oil for VE-TDI: <3.4 mPa.s Quote
Hello Sepp,
almost correct.
You can use 'normal' oil in a LongLife vehicle, but with a fixed oil change interval (every 15,000 km). However, for TDI-PD engines, it is essential to use oil that meets the 505.01 standard (which is for PD engines without the LongLife designation). For gasoline engines, use oil that meets the VW 502.00 standard.
Under no circumstances should long-life oil (HTS < 3.4) be used in a vehicle that has not been approved for long-life oil. This will inevitably lead to bearing and engine damage at high temperatures and under load.
Translated on 11-10-2026, 7:45.
