2.0 CR TDI Timing Belts... Volkswagen Timing Belts in general.
dleds
Karma: +13 / -1   Thank you, like it!
Post11-07-2026, 18:13    Subject: 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in general. Quote
Hey everyone,
I'm sitting here writing this, and I'm so angry that steam is practically coming out of my ears. Does anyone happen to know how to adjust the camshaft timing on an EA189 engine? Specifically, which tooth engages with which?
It can't be serious that you have to mount and dismount the valve cover five times before finding the right position where the slot on the back of the camshaft is somewhat aligned with the edge of the cylinder head.
...which then leads me to a point of contention that has been ongoing for 20 years. What was going through the minds of those at Volkswagen when they were figuring out how to control and manipulate the timing of their engines?
Warum, muß die KW Ot Marke durch ein Loch in der Getriebeglocke erstmal unter Rost freigelegt werden. Und warum ist es zwingend notwendig mindestens den Ventildeckel zu demontieren um die Steuerzeiten der Nocke zu kontrollieren. Kein anderer Großserienhersteller bricht sich dabei so einen ab wie der VAG Konzern.... Um den Kreis zu schließen, ich möchte nicht wissen wie viele 2.0 CR mit einer verstellten Nockenwelle durch die Gegend fahren. AnInstead of adding three detent balls to the mechanism from the factory, which would indicate where each tooth should align.
...the trick is probably similar to that used with 2.5-liter overhead cam engines: assemble the timing gears without the rocker arms first, and then set the timing marks yourself.
Just to give you an idea, I recently had a Opel 2.8 V6 Turbo in my shop that needed timing chain replacement. The owner couldn't find anyone willing to do the job. I had it scheduled for two days with a possible third day because the engine might need to be removed. It has three chains, four camshaft adjusters, balance shafts, and the oil pump – all connected under one cover. I've never done this before, and I didn't have any instructions for it. What can I say? Any mechanic should be able to do this with basic tools in a single day. The whole thing is designed according to the Poka Yoke principle; you simply can't assemble it incorrectly. Changing the timing belt on a TDI engine is less complicated than this.
Translated on 11-07-2026, 19:33.
Karma: +786 / -0   Thank you, like it!
Post11-07-2026, 19:31    Subject: 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in general. Quote
Did I miss something? icon_biggrin.gif Do you have any pictures?
Translated on 11-07-2026, 19:32.
dleds
dieselschrauber likes this.
Post12-07-2026, 9:28    Subject: 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in general. Quote
"I had to replace the camshafts. They are connected to each other via a toothed coupling. You can fix the exhaust camshaft with a 6mm dowel pin if the camshaft cover is fully assembled. The intake camshaft, as usual for VW, is aligned using a ruler on the cylinder head. However, this can only be done if the camshaft cover is missing. The problem is that the camshafts rotate when tightening the cover, so you lose the initial setting no matter what you do."
Ich hab mir die Lösung aber schon selbst genannt, man muß die Schlepphebel rausnehmen, dann können die Nocken so in die Gassen gelegt und abgesteckt werden, danach kann man die Position mit Lack zueinander markieren. Problem hierbei war mein kalibriertes Auge icon_wink.gif ich hatte bei der ersten Montage eine Abweichung festgestellt, die Nocke war nicht in Flucht mit der Kopf-Planfläche wenn abgesteckt. Das Gleiche habe ich dann mit dem Abstecklineal festgestellt, die Nockenwellen (FEBI) sind in der Verzahnung nicht passend zum Kopf. Einen Zahn weniger oder mehr ist aber noch weiter weg. I reluctantly chose the option with the least bad value.
The whole problem could have been avoided if the gears had a marking (e.g., "tooth X on base Y"). This would also prevent the 180-degree rotation, as the centering slot is in the middle.
The whole thing is incredibly poorly designed. A single design flaw can cause the entire engine to fail.
Translated on 12-07-2026, 12:11.
Karma: +1322 / -0   Thank you, like it!
Post12-07-2026, 10:45    Subject: 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in general. Quote
Hi there,
When assembling with the installation tool, a positioning gauge is used to lock the intake camshaft, and a cover is used to lock the exhaust camshaft (for RLF EA188 Gen.2 and CJCD engines).
Okay, here's the translation:
"Edit: of course, it's an EA189 Gen.2."
Translated on 12-07-2026, 11:30.
dleds
Post12-07-2026, 12:33    Subject: 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in general. Quote
I was almost certain that this poor design would require another set of specialized tools, like a wheelbarrow full. And then for the 288 model, it's all over again – there's no other way; a new engine means new tools.
I now have almost a whole room full of obsolete tools simply because the people at Volkswagen are too incompetent to come up with something better, cheaper, or more sensible.
It's not that Volkswagen lacks the invested capital; it's simply poorly executed. It frustrates me because things could be simpler and more affordable for everyone.
Just think about the "dieselgate" scandal at Volkswagen. So much capital was wasted for absolutely nothing.
Translated on 12-07-2026, 12:55.
huebi likes this.
Post13-07-2026, 7:10    Subject: 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in general. Quote
I'm having trouble understanding your approach and your criticism.
The crankshaft has been fixed in the top dead center (TDC) position since the end of the Variable Valve Timing (VVT) era using a crankshaft locking tool, not through a viewing hole.
The two camshafts are assembled in a specific position: first, each is set to Top Dead Center (TDC) individually, then joined together and placed into the bearing housing. There is no phase offset. Finally, the bearing housing with the two fixed camshafts is mounted onto the crankshaft. The spur gears prevent the camshafts from being mounted individually onto the crankshaft.
Translated on 13-07-2026, 7:11.
No new posts Leistungsverlust, Luftmasse/Ladedruck/Steuerzeiten ok Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Steuerzeiten AKN Diesel Engine Technology
No new posts Tax hours Diesel Engine Technology
No new posts Steuerzeiten bei V6 TDI AKN Diesel Engine Technology
This topic is locked, you cannot edit or reply. Adjusting valve timing 1.9 TDI PD AXR Diesel Engine Technology
