Cold Start Problem Solved - [Solution]:-) | Posts 16+
Go to page: Previous  1, 2
Post29-11-2003, 22:13    Subject: Cold Start Problem Solved - [Solution]:-) Quote
Derby-Oli wrote:
....dass ein solcher Kerzenzustand von einem defekten Einspritzventil verursacht werden kann. Is that right? / Is that true?
... it might be the case, but it doesn't necessarily have to be. However, the probability is high. Therefore, it is essential to have the ESDs checked.
Translated on 21-08-2026, 14:52.
Post29-11-2003, 23:11    Subject: Cold Start Problem Solved - [Solution]:-) Quote
Gremlin wrote:
I've also cursed the old TD models before.
ulf, have you ever worked on one of these before? It's a typical example of VAG engineering...
Hi Ralf,
I haven't assembled it myself yet, but I'm starting to remember approximately how some of the candles are installed on it. icon_mad.gif
No new posts Starting Problems 2.5 TDI Engine Diesel Engine Technology
No new posts Cold start problem PD AUY Diesel Engine Technology
No new posts Cold start problem 2.5 TDI V6 Diesel Engine Technology
No new posts 1.9 TDI Cold Start Problem Diesel Engine Technology
