Motoraussetzer AFN 81kW | Posts 16+
Go to page: Previous  1, 2
Jan6K
Avatar-Jan6K
Post17-12-2003, 8:12    Subject: Quote
I'm not so sure about the "backwards flow," because, in my opinion, these are LEDs, not incandescent bulbs, and they only light up with the correct polarity.
I don't know how it was in your T3 from 1987, but at least my parents' gasoline Passat, also from 1987, had LEDs as indicators.
Jan.
1Z5 CFHF / AHB H4D
Translated on 17-09-2026, 4:57.
Wolfgang, syncro16
Post17-12-2003, 10:43    Subject: Quote
I'm not so sure about the 'reverse flow,' because, in my opinion, these are LEDs, not incandescent bulbs, and they only light up with the correct polarity.
You're probably right, but this is a simple matter to determine: if nothing moves on the valve, then what I wrote above doesn't apply.
That means the problem is likely located somewhere in the alternator or its grounding. Older T3 models sometimes have grounding issues, so I would start by investigating that.
Hello.
Wolfgang.
Translated on 17-09-2026, 4:58.
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post17-12-2003, 17:32    Subject: Quote
Hi Wolfgang,
I have a "real" incandescent bulb as a preheating lamp, not an LED. It was added later, because it was originally a gasoline engine. The preheating lamp is connected directly to the corresponding pin on the engine control unit (ECU) and then goes to ground. Or does the ECU switch it to ground? I'm not entirely sure about that, I'll have to check. So, a "back current" through the instrument cluster is ruled out.
Why the alternator? The mass problem should rather be related to the control unit. And the battery is still there; the car sometimes runs even without the alternator. I haven't started looking yet, but I want to start as soon as my wife gets home by bus icon_wink.gif.
The weight distribution from the engine/transmission to the body should be fine, as I frequently remove and reinstall the transmission, so the relevant connections are often checked.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 17-09-2026, 5:00.
Wolfgang, syncro16
Post17-12-2003, 17:50    Subject: Quote
Hello Jens,
The engine likely enters a temporary emergency mode because, at the same time, the charging control light illuminates and the turbo pressure drops.
Um, I was thinking of the red indicator light for load control, the one that's connected between terminal 15 and generator D+. If you meant something else, then you can disregard everything I've written above.
Does the tachometer now move when the light comes on?
Hello.
Wolfgang.
Translated on 17-09-2026, 5:02.
Jens 16syncro
Post17-12-2003, 23:50    Subject: Quote
Hello Wolfgang,
"Argh, I meant the preheating lamp. What nonsense about the charging control lamp icon_redface.gif."
No, not a bit.
I just bypassed the ignition switch and the wiring to the rear by directly applying 12V to the control unit (via a switch). The first test drive was without any interruptions icon_rolleyes.gif.
It could very well be the ignition switch, so I'll need to bypass it directly tomorrow.
Jens.
Translated on 17-09-2026, 5:03.
Jens 16syncro
Post21-12-2003, 9:16    Subject: Quote
It's not the ignition switch, because that's actually new, installed yesterday. Unfortunately, the effect is still there, and it feels even stronger than before icon_evil.gif.
"I've also noticed that the regulator for the alternator seems to be faulty. The voltage in the vehicle's electrical system is only around 13.0V with the engine running, regardless of the engine speed."
icon_exclaim.gif icon_question.gif Well, there will be a new one tomorrow.
There are some wireworms around somehow icon_evil.gif.
Jens.
Translated on 17-09-2026, 5:04.
Wolfgang, syncro16
Post21-12-2003, 20:53    Subject: Quote
Hello Jens,
In that context, it would also be interesting to know what happens when the onboard voltage is too high. Is there a specific error message for that? What voltage can the control unit still tolerate? Does it automatically shut down for safety reasons?
And by the way: There are also special regulators for the alternator that are used to charge the on-board battery. These regulators don't keep the on-board voltage constant either. I wonder if the control unit can handle that?
Hello.
Wolfgang.
Translated on 17-09-2026, 5:06.
Post22-12-2003, 16:27    Subject: Quote
Hi Jens,
The light bulb turns on while the engine is about to turn off, which, in my opinion, is likely caused by a voltage drop at terminal 15 - if your EDC is wired the same way as in the AFN Golf 3, it will react exactly like that.
Translated on 17-09-2026, 5:07.
Jens 16syncro
Post22-12-2003, 19:08    Subject: Found it! - [Your Search Term] Quote
The error has been located and fixed icon_smile.gif.
It was a loose connection on the starter motor, where terminal 30 of the alternator connects. This was also the cause of the low voltage in the vehicle's electrical system; the voltage regulator was not the problem.
I'm wondering why the battery voltage isn't sufficient to keep the motor running. Is it absolutely necessary to have a fully functional alternator?
Jens.
Translated on 17-09-2026, 5:08.
No new posts Can injectors from an 81kW ASV engine be used in an 81kW ... Diesel Engine Technology
No new posts Engine Failure: Causes and Solutions Diesel Engine Technology
No new posts 1.9 TDI Engine Failure: Causes & Solutions Diesel Engine Technology
