Power Loss: Causes and Solutions (02-01-2004, 22:11)
hoerneli
Post02-01-2004, 22:11    Subject: Power Loss: Causes and Solutions Quote
Hello or Houston, I have a problem!
'In my Ford Galaxy TDI with 90 horsepower that has been chipped to 115 horsepower, the power is reduced when accelerating fully in the higher gears (4th and 5th), starting around 3500-4500 RPM.'
It's not the ultimate emergency program, as the car gets stuck at 120 km/h.
I suspect the boost pressure control valve.
Not as extreme in the lower levels. Does anyone have a clue?
Best regards, Jörn.
Translated on 17-08-2026, 13:06.
WarLord
Post02-01-2004, 22:41    Subject: Power Loss: Causes and Solutions Quote
Does the power output decrease starting at 3,500 RPM? Is it a sudden drop or a gradual reduction?
Best regards, WarLord.
Translated on 17-08-2026, 13:07.
Dan.jel
Post03-01-2004, 1:40    Subject: Power Loss: Causes and Solutions Quote
1. Search function.
hoerneli
Post03-01-2004, 16:37    Subject: Power Loss: Causes and Solutions Quote
Hello!
The engine power cut out intermittently between 3500 and 4500 RPM. Today, I replaced the charge air cooler control valve and all the hoses. The vacuum hose and reservoir on the turbocharger were full of oil. I cleaned everything thoroughly and reinstalled it properly. It seems to be working okay after my first test drive.
P.S. Of course, I checked the forum!
Thank you for the answers.
Best regards, Jörn.
Translated on 17-08-2026, 13:08.
No new posts Octavia 1z 2.0 TDI BMM hat Leistungsverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leistungsverlust AUY 85 KW Diesel Engine Technology
No new posts Leistungsverlust am G3 TDi!!! Diesel Engine Technology
No new posts Power loss and ABS Diesel Engine Technology
No new posts AJM, Performance loss from 130 km/h Diesel Engine Technology
