Boost Pressure Too High: No Tuning Needed?
Marzocchi
Post19-01-2004, 15:37    Subject: Boost Pressure Too High: No Tuning Needed? Quote
Hello. I've already tried searching, but I haven't found a solution to my problem.
I have a 66kW ALH TDI engine in my Golf IV. I recently installed a boost gauge and noticed that it's showing overboost, sometimes up to 1.5 bar. It might even be a bit higher, as the gauge reaches its maximum at that point.
"When activated, the boost pressure indicator shows a reading between 0.9 and 1 bar. This should be normal. However, the overboost values should normally not exceed 1.3 bar. I haven't made any modifications to my engine. What could be the cause? I know I can adjust the VTG linkage to limit the overboost, but that shouldn't be the solution for an engine that's not tuned for high boost. There must be a reason for this. I appreciate any answers."
Golf IV - ALH - Erstzulassung 9/99
Translated on 10-09-2026, 11:13.
Post19-01-2004, 15:42    Subject: Boost Pressure Too High: No Tuning Needed? Quote
Hi.
Does the ALH engine have the LD sensor, including the LL temperature sensor, integrated into the LLK (low-temperature coolant)?
That means there is no hose connecting the intake manifold to the MSTG (like in the 1Z, AFN, etc. engines).
How and where did you connect the LD display?
What did you drill?
Perhaps the reason is this (although I'm surprised by the seemingly plausible values).
Translated on 10-09-2026, 11:14.
Marzocchi
Post19-01-2004, 15:52    Subject: Installation Guide: How to Install It Quote
Hello. I installed the advertisement as follows:
http://members.void.at/axel/Auto/Tips/LDA/lda.htm
Translated on 10-09-2026, 11:15.
christians
Post19-01-2004, 16:48    Subject: Boost Pressure Too High: No Tuning Needed? Quote
It can't be due to the indicator or its connection. Have you checked the functionality of the VTG adjustment? The LDR valve will likely remain stuck for a while.
Gruß Christian
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Code P2463: High Soot Mass Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High Boost Pressure, ASZ Engine Diesel Engine Technology
No new posts AFN: High Boost Pressure - Troubleshooting On-Board Diagnostics (OBD)
No new posts Boost Pressure at 10 Ct on ESP - Too High? Diesel Engine Technology
No new posts Boost pressure too high On-Board Diagnostics (OBD)
