1,4 TDI Kaltstart | Posts 16+
Go to page: Previous  1, 2
joergs
Post22-01-2004, 19:54    Subject: Quote
My former favorite colleague has a Peugeot 75 hp model, manufactured in December 2002. It also doesn't have any starting problems or an unstable idle, even when the temperature outside is below -10 degrees Celsius.
Translated on 17-09-2026, 16:26.
Olaf
Post23-01-2004, 16:23    Subject: Quote
@Joohn
Okay, so let me reiterate: A rough idle and noticeable clattering are normal for a 3-cylinder PD engine. You can't compare it to a 4-cylinder common rail engine. However, you also get more torque and lower fuel consumption with a PD engine.
The idle speed can sometimes be slightly lower than normal for about half a second to one second during a cold start in sub-zero temperatures, especially if you haven't preheated the engine or if you're using 100% biodiesel. Otherwise, something is likely wrong.
Olaf.
P.S.
I fill up with all sorts of things (including E10, but usually only up to 50%).
Translated on 17-09-2026, 16:27.
Back to top Profile PM Email
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Clattering noises after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Improves Cold Start Performance On-Board Diagnostics (OBD)
No new posts Cold Start Diesel Engine: 101 PS Below 0°C Diesel Engine Technology
No new posts Cold Start: How to Safely Merge onto Highway Diesel Engine Technology
No new posts AXC cold start at 18°C with 1-2 misfires Upload
