kossmann Blaumann
2016 Audi Q3 Premium Support
15-03-2004, 18:28 Subject: Idle Speed Control: How to Adjust It |
Hello everyone,
I recently used VAG-Com to monitor my Audi 80 1.9 TDI (1Z), which has 152,000 km and was manufactured in March 1994, and I noticed some values in group 13 that caught my attention – specifically, the idle speed control.
While idling, I recorded the following values:
Cylinder 4 (Target: -2 to +2) = 4.51 mg/revolution.
Cylinder 2 (Target: -2 to +2) = 1.18 mg/R.
Cylinder 1 (Target: -2 to +2) = 2.55 mg/rotation.
Cylinder 3 is not listed; I suspect that's correct (since the NHG is located there, right?)
What do these deviations from the target values mean, especially since cylinder 4 shows an extreme deviation?
Thank you!
Translated on 11-08-2026, 6:05.
Profile PM Email Garage |
joergs Guest
15-03-2004, 19:00 Subject: Idle Speed Control: How to Adjust It |
No offense, but the search function sheds light on things! There have been many, many discussions about it.
and cylinder 3 is indeed the NHG!
Translated on 11-08-2026, 6:06.
kossmann Blaumann
15-03-2004, 19:07 Subject: Idle Speed Control: How to Adjust It |
When I search for "Ruheregelung," I only find one thread... and there's actually nothing interesting in it.
Translated on 11-08-2026, 6:07.
Bertil Profi-Schrauber
15-03-2004, 20:04 Subject: Idle Speed Control System |
Tino Kossmann wrote: |
In the VP engine, the third cylinder serves as the reference cylinder and is therefore always equal to zero.
It's normal for your engine to run unevenly.
Why are there discrepancies?
Uneven compression (for whatever reason), uneven spray pattern from the nozzles... Gruß Bertil
Translated on 11-08-2026, 6:08.
kossmann Blaumann
15-03-2004, 20:11 Subject: Idle Speed Control: How to Adjust It |
That doesn't sound good at all... I was planning to replace the needle valve anyway. Should I also replace the other injectors at the same time, or is there a cheaper way to do it?
Translated on 11-08-2026, 6:09.
joergs Guest
15-03-2004, 20:25 Subject: Idle Speed Control: How to Adjust It |
I can't find the threads right away either, but here are a few more points to consider regarding Bertil's comments:
- faulty vibration damper
- Problems caused by uneven running of auxiliary equipment.
- Uneven opening pressure at the nozzles.
mersente Guest
15-03-2004, 20:30 Subject: Idle Speed Control: How to Adjust It |
Hello, if you want to replace the injector driver, you should at least clean the other injectors and, if necessary, have them repaired. It's best to do this at Bosch.
Translated on 11-08-2026, 6:10.
kossmann Blaumann
15-03-2004, 20:34 Subject: Idle Speed Control: How to Adjust It |
Do you happen to know approximately how much it costs to get a print?
mersente Guest
15-03-2004, 20:42 Subject: Idle Speed Control: How to Adjust It |
It depends on the technician; if you're lucky, they might do it for 5 or 10 euros. Otherwise, it's probably closer to 30 euros (assuming the nozzles are removed).
Translated on 11-08-2026, 6:11.
