Golf ALH Relay: Always On in Cold Weather
totto2k
Post04-04-2004, 18:50    Subject: Golf ALH Relay: Always On in Cold Weather Quote
Hello, I've noticed for some time that a relay is constantly clicking when accelerating from a cold start (presumably in the box under the steering wheel).
What could it be? Is it normal for it to shift gears frequently, or is it normal to hear it making that much noise?
Sure, no problem! Here's the translation:
'Thank you in advance!'
Thorsten.
Translated on 21-10-2026, 17:58.
Post04-04-2004, 18:55    Subject: Golf ALH Relay: Always On in Cold Weather Quote
totto2k wrote:
Hello, I've noticed for some time that when accelerating from a cold start, a relay constantly clicks (presumably in the box under the steering wheel).
What could that be? Is it normal that it shifts gears frequently, or is it normal that you can hear it so loudly?
Hi Thorsten,
If it's always clicking around 2500 rpm, it's likely the glow plug relay.
The afterglow is interrupted above 2500 rpm, and resumes below 2500 rpm.
The ALH continues to glow "for a very long time."
Translated on 21-10-2026, 18:00.
totto2k
Post04-04-2004, 19:45    Subject: Golf ALH Relay: Always On in Cold Weather Quote
Thank you for the response.
It helped me a lot. The thing about the speed is roughly correct.
I'll pay attention to whether I'm really letting it cool down long enough, or if I'm rushing things, because maybe that's making it worse.
Greetings,
Thorsten.
Translated on 21-10-2026, 18:01.
Post04-04-2004, 19:47    Subject: Golf ALH Relay: Always On in Cold Weather Quote
totto2k wrote:
I'll pay attention to whether I'm really letting it cool down long enough, or if I'm being too hasty, maybe it will get worse because of that...
That has nothing to do with preheating.
The afterglow function may activate depending on the engine temperature, even when preheating is not actually necessary.
Translated on 21-10-2026, 18:02.
Avatar-Jan6K
Post04-04-2004, 21:10    Subject: Golf ALH Relay: Always On in Cold Weather Quote
You should try not to rev the cold engine above 2500 RPM, ideally not above 1500-2000 RPM. This will prevent the relay from clicking, and the engine will be happier too.
Jan.
1Z5 CFHF / AHB H4D
Translated on 21-10-2026, 18:03.
WarLord
Post04-04-2004, 21:18    Subject: Golf ALH Relay: Always On in Cold Weather Quote
Okay, so I usually don't rev a cold engine above 2,000 RPM (except for gasoline engines, which can handle a bit more when cold; ours, being small, gets to 2,500 RPM), but I wouldn't shift below that.
Best regards, WarLord.
totto2k
Post04-04-2004, 21:31    Subject: Golf ALH Relay: Always On in Cold Weather Quote
Okay, let's check on it tomorrow morning. I'll try to keep it at 2000 [units - assuming a temperature or pressure reading] until it reaches 90 degrees.
Thanks, guys!
Thorsten.
Translated on 21-10-2026, 18:04.
No new posts Golf 1J: Gear Shift Problems in Cold Weather Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dashboard warning light for airbag "OFF" is constantly il... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Touran: GRA Disengagement Explained Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vacuum in Cold Conditions Diesel Engine Technology
No new posts 1.9 TDI PD: Cold Start Problems & Solutions Diesel Engine Technology
No new posts ARL Noises: Troubleshooting Cold Start Issues Diesel Engine Technology
No new posts CFFB Shakes in Cold Weather Diesel Engine Technology
