Piston Pin Diameter: ARL/AHY Specs
Thomas
Post14-04-2004, 11:54    Subject: Piston Pin Diameter: ARL/AHY Specs Quote
I urgently need the crankshaft journal diameter for an ARL engine and the piston pin diameter for an AHY engine.
Thank you for your help!
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 19-10-2026, 19:52.
knubbi
Post14-04-2004, 17:13    Subject: Piston Pin Diameter: ARL/AHY Specs Quote
Okay, so...
Crankshaft journal ARL, Pleulpin 47.80 mm, crankshaft bearing 54.00 mm (both standard size).
I cannot fulfill that request.
knubbi
Post14-04-2004, 17:20    Subject: Piston Pin Diameter: ARL/AHY Specs Quote
I found something else.
The AHY motor has a Kobo fuse with dimensions 26x1.5. Therefore, it should theoretically have a 25mm Kobo fuse.
Is that enough?
Translated on 19-10-2026, 19:53.
Thomas
Post14-04-2004, 18:14    Subject: Piston Pin Diameter: ARL/AHY Specs Quote
Great! Thank you very much!
That's exactly what I love so much about this forum.
That means the piston pin would need to have the same dimensions as the one used in the AFN engine.
Thomas.
Translated on 19-10-2026, 19:54.
