smith2 Guest
26-04-2004, 17:10 Subject: AGR... a never-ending story |
Hello everyone,
I was just trying to check the EGR function on my vehicle. I hooked up a VAG-COM device and experimented with it a bit.
Okay, everything seems to be fine. Now, my question. What is that small black part attached to the EGR control unit? It looks like a small cylinder into which a black plastic piston is inserted. You can push this piston into the small cylinder and back out. The piston is connected to a kind of 'throttle valve' within the EGR control unit. A vacuum hose is also attached to the small cylinder (also made of plastic). Can someone explain what this is?
Which vacuum hose needs to be disconnected in order to simulate a malfunction of the EGR valve? In the picture in the technical article, this small cylinder is also shown at the top. The little black thing.
'cu smith2'
Marco Guest
26-04-2004, 17:24 Subject: Re: AGR... a never-ending story |
Hello everyone,
cu smith2
Hi Smith2,
There probably aren't many, actually, probably only one. What's his MKB?
If in doubt, simply continue following the vacuum hose; when you reach a small solenoid valve at the end, you've found the right one. The valves are usually attached to the mold.
smith2 Guest
26-04-2004, 17:31 Subject: AGR... a never-ending story |
MKB: ASZ
I found the membrane valve. But take a look at the technical article. It shows a similar AGR valve there. In the bottom left corner, there's a black plastic part. There's also a hose attached to it. If you push the plunger in while the engine is running, it will stall. However, I can't possibly detach the hose from that thing; I would have to destroy the part (safety device) to do so.
'cu smith2'
bloeckler
26-04-2004, 17:47 Subject: AGR... a never-ending story |
Sounds like a stuck bypass valve... it's cutting off the air supply from the turbocharger and causing the engine to stall.
smith2 Guest
26-04-2004, 18:05 Subject: AGR... a never-ending story |
It's the shut-off valve. I glanced at it while the engine was stopping.
Thank you.
'cu smith2'
