Fuel consumption for gasoline engines?
Adrian
Post09-07-2002, 21:43    Subject: Fuel consumption for gasoline engines? Quote
Can someone tell me how to extend the Ulf's DZR (Dynamic Rotor Speed) to 6000 RPM? I tried copying and pasting it into Excel. Is there anything else I should be aware of?
It would be interesting to calculate whether a diesel engine can climb a highway incline faster than a gasoline engine with the same horsepower.
Best regards.
Adrian.
Docter
Post12-07-2002, 17:40    Subject: Fuel consumption for gasoline engines? Quote
I've done that before...
However, not all updates were followed icon_wink.gif.
However, this is not suitable for comparing the systems...
Where is the difference in acceleration supposed to be when going uphill?
Post12-07-2002, 19:41    Subject: Fuel consumption for gasoline engines? Quote
I would say that as long as the torque curve of a naturally aspirated gasoline engine isn't completely messed up, there shouldn't be significant differences. The differences are likely even smaller in turbocharged gasoline engines.
When you compare the 0-100 km/h acceleration times of similarly powerful gasoline engines and TDI engines, they are often very similar.
Okay, gib mir den deutschen Text.
Converting a 150 horsepower turbocharged gasoline engine in a Golf 4 to a 150 horsepower TDI diesel engine from Volkswagen.
8.5 to 8.6 seconds.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts BFQ 1.6 Petrol Engine Gasoline Engine Technology
No new posts Error code in A3 8PA gasoline engine Gasoline Engine Technology
No new posts Benziner Drehzahlmesser mit tdi stg On-Board Diagnostics (OBD)
No new posts Hydraulic lifters 3.7 gasoline engine Gasoline Engine Technology
