Which AHF fuel injectors?
scherle
Post28-04-2004, 9:14    Subject: Which AHF fuel injectors? Quote
Hi there!
I would like to replace the fuel injectors in my Golf IV automatic transmission (AHF) with the 216 injectors. Does anyone know if the automatic transmission uses the same injectors as the manual transmission?
Best regards.
Scherle.
PrivatBereich
Post28-04-2004, 9:26    Subject: Which AHF fuel injectors? Quote
Hello Scherle,
You can figure that out yourself! Go ahead.
icon_arrow.gif on top of 'vehicle'
icon_arrow.gif Then you enter your data (e.g., via engine codes) and select your vehicle and engine.
icon_arrow.gif When selecting the assembly group, choose 'Fuel processing --> Nozzles --> Nozzle holder'.
Now you can see what types of nozzles are available for your vehicle, and whether there are different ones for automatic and manual transmissions. (For each engine, at least two part numbers are always displayed; by viewing the item details, you can see that one is equipped with a needle movement sensor (NMS) and one is not.)
Private.http://www.bosch-automotive.com/ecat-online/{MARKER}
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Injection Nozzles for ALH Engines Diesel Engine Technology
No new posts TDI Injectors: Which Models Use the Same? Diesel Engine Technology
No new posts Which spark plugs? Diesel Engine Technology
No new posts What boost gauge? Diesel Engine Technology
