Gewinde in der Ölwanne kaputt! | Posts 16+
Go to page: Previous  1, 2
donalexo
Post06-05-2004, 11:31    Subject: Quote
@wbuchi82Viewing profile: wbuchi82:
However, to use the repair kit, you still need to remove the oil pan in order to be able to remove any debris, right?
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 07-08-2026, 12:09.
haehnlein
Post06-05-2004, 11:40    Subject: Quote
That's just so frustrating with the workshops... they're too lazy to even pick up a torque wrench icon_evil.gif.
I once read somewhere about a repair kit for oil pan screws. I think it was in the catalog from www.stahlgruber.de, but I'm not sure... Good luck.
____________
Kein Auto mehr!
Translated on 07-08-2026, 12:10.
Gremlin
Post06-05-2004, 13:20    Subject: Quote
So, anyone who needs a torque wrench for an oil drain plug is definitely a hopeless clumsy person icon_wink.gif.
CU Gremlin.
Translated on 07-08-2026, 12:11.
haehnlein
Post06-05-2004, 14:00    Subject: Quote
Gremlin wrote:
So, anyone who needs a torque wrench for an oil drain plug is definitely a hopeless clumsy person.icon_wink.gif
The oil pan screw master from wbuchi82 would definitely have said it like this icon_wink.gif. Well, safety is my priority as an amateur mechanic, and I still have the time to take a torque wrench in my hand for 30 seconds.
I was once laughed at in a workshop because I got upset that the self-locking nuts on the axle weren't replaced during the wheel alignment (let alone using a torque wrench). The master mechanic told me, "no workshop does this," but then all four screws on the axle joints came loose on the highway, almost breaking my neck icon_evil.gif. They probably rolled their eyes when I showed up at the door again a day later.
That's all there is to say about the topic of "feeling."
____________
Kein Auto mehr!
Translated on 07-08-2026, 12:12.
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post07-05-2004, 18:56    Subject: Quote
Okay, I finally did it!
I inserted the threaded bushing and then we milled the sealing surface again. However, the milling shouldn't have been necessary. But during the first drilling attempt, it "ate" the drill bit a little. The threaded bushing is now such a hard material that even the most experienced workshop technician can't damage the threads anymore! icon_lol.gif
But I agree with "haehnlein," I am also a proponent of using a torque wrench! There's nothing worse than screws that are tightened incorrectly. Thank you again for your answers. This repair cost about €30 now! So, I was spared the expense of buying a new oil pan, all because of a single, ruined thread. icon_biggrin.gif
Best regards.
WBUCHI
[img][/img]
Translated on 07-08-2026, 12:14.
Back to top Profile PM Email
haehnlein
Post07-05-2004, 20:17    Subject: Quote
Did you remove the tub for the drilling operation?
____________
Kein Auto mehr!
Translated on 07-08-2026, 12:15.
Gremlin
Post08-05-2004, 10:40    Subject: Quote
That's all there is to say about the topic of 'feeling'.
Well... an oil drain plug and the suspension are two completely different things, right?
We don't make compromises here either...
but 25 years without a torque wrench on the oil pan and without any complaints, that speaks for itself, doesn't it? icon_wink.gif
by the way...the injection lines cannot be sealed properly even with the prescribed torque icon_wink.gif.
CU Gremlin.
Translated on 07-08-2026, 12:16.
Julian
Post08-05-2004, 10:46    Subject: Quote
but 25 years without using a torque wrench on the oil pan .
A professional would never use a torque wrench on the oil pan. They have a feeling for it.
Translated on 07-08-2026, 12:17.
wbuchi82
Post08-05-2004, 12:15    Subject: Quote
@haehnleinViewing profile: haehnlein
Yes, the oil pan obviously had to be removed. Without proper alignment and a perfectly vertical fit, it simply won't work. Also, all debris should be removed from the oil pan. I had already managed to extract some small shavings from the coarse intake filter. These shavings likely entered the oil when the threads were loosened. However, removing it wasn't a problem (at least on the A3 8L).
Best regards.
[/quote]
Translated on 07-08-2026, 12:18.
WarLord
Post09-05-2004, 11:19    Subject: Quote
Hmm, a torque wrench might also be useful for me sometime, but I've always tightened the drain plugs on the oil pan by feel (after tight comes loose icon_twisted.gif).
Best regards, WarLord.
Translated on 07-08-2026, 12:19.
No new posts Oil Drain Plug Stripped? Get Help Now! Diesel Engine Technology
No new posts Thread for oil pressure gauge? Diesel Engine Technology
No new posts Injector Threads for VW/Audi AFN/1Z Engines Diesel Engine Technology
No new posts AFN, spark plug, stripped threads, help!!! Diesel Engine Technology
