Air Mass Meter Audi 90 20v
Fletcher
Post13-05-2004, 21:22    Subject: Air Mass Meter Audi 90 20v Quote
Hi!
I have a problem with my air mass meter. I think so, so the engine has a spark, air, and fuel! But it won't start! After I try to start it and then remove the spark plugs, they are completely wet!
So, I guess it's the LMM!?!?!
This will cost around €300 at VW/Audi though!! Are there any solutions, or can I somehow measure it through?
Could someone please help me? As quickly as possible!!
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post13-05-2004, 22:21    Subject: Air Mass Meter Audi 90 20v Quote
Do you definitely still have an air flow meter in there?
B.Eng (FH) u. KFZ Meister
Fletcher
Post14-05-2004, 1:30    Subject: Air Mass Meter Audi 90 20v Quote
Hello!
No! Don't believe!!! So, one with a grid! HFM just now!!!
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post14-05-2004, 8:04    Subject: Air Mass Meter Audi 90 20v Quote
Okay, if it's an HFM, I unfortunately don't know if it will fit with the Audi 90.
from PD-VP Tdi -V6 TDI are all the same and you can even swap them with each other.
Even with gasoline engines, whether 1.8T, 1.6, 1.8, 2.4, or 2.6. They are all the same.
Cost: 75 Euro in exchange.
Therefore, I suggested that we simply replace it with another one. icon_cool.gif icon_cool.gif
Fletcher
Post14-05-2004, 11:26    Subject: Air Mass Meter Audi 90 20v Quote
I've also been considering this, but is HFM = HFM?????
So, the plug has four pins!
No new posts Mass Air Flow Sensor (MAF): Expensive Weak Point in VAG T... Technical Articles
No new posts Mass flow meter / Mass flow values for gasoline engines General Tips
No new posts 16488/P0104/000260 - Mass Air Flow Sensor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air mass meter On-Board Diagnostics (OBD)
No new posts Luftmassenmesser Korrekturschaltung Diesel Engine Technology
No new posts Luftmassenmesser von Ebay? Diesel Engine Technology
No new posts Die Geschichte vom Luftmassenmesser Diesel Engine Technology
