Passat 3B ZR Replacement
C.F.
Post16-07-2002, 10:22    Subject: Passat 3B ZR Replacement Quote
Hi.
Does the entire front of the Passat 3B with a 90hp TDI engine need to be removed for the timing belt replacement, like with the A4, or can it be done without removing the front?
Best regards, Claus.
Translated on 07-10-2026, 16:44.
Cheffe
Post16-07-2002, 13:14    Subject: Passat 3B ZR Replacement Quote
You don't need to remove the front panel; you can access it this way.
*Mario
Translated on 07-10-2026, 16:45.
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Used ATL 35i Passat, engine 1Z Diesel Engine Technology
No new posts Passat Diesel Filter Replacement Diesel Engine Technology
No new posts No power after timing belt/chain replacement / Passat TDI... Diesel Engine Technology
No new posts ZR change in PDs? Diesel Engine Technology
