'I'm sorry, I forgot.'
Fabia TDI PD, engine code 038 906 019 HT, 1.9L R4 EDC 0000SG, production date 1503 (March 15th).
Group 000 represents the default values when the engine is not running.
Group
000 0, 0, G-Pedal [0-255], 0, 96, 196, 159, 172, 88, 255
001 RPM [1/min], Injection amount [mg/stroke], Idle stability [CF], Temperature [°C]
002 revolutions per minute [RPM], Load [percentage], Binary bits, Temperature [degrees Celsius].
003 revolutions per minute [rpm], Mass flow rate of air per revolution [mg/rev], Mass flow rate of air per revolution [mg/rev], Duty cycle [%]
004 u/min [1/min], Zünd. Verstell [°BTDC], Leerlauf Stabi. [CF], Leerlauf Stabi. [[CF]
005 revolutions per minute [rpm], Injection amount [mg/dose], (no unit), Temperature [°C].
006 Speed [km/h], Binary bits, Load [%], (no unit)
007 Temperature [°C], Duty Cycle [%], Temperature [°C], Temperature [°C].
008 u/min [1/min], Inj. Menge [mg/R], Inj. Menge [mg/R], Inj. Amount [mg/R]
009 u/min [1/min], Inj. Menge [mg/R], , Inj. Amount [mg/R]
010 Mass Air Flow / Revision [mg/R], Absolute Pressure [mbar], Absolute Pressure [mbar], Load [%]
011 revolutions per minute [rpm], Absolute pressure [mbar], Absolute pressure [mbar], Operating frequency [%]
012 Binary. Bits (no unit), Volts [V], Temperature [°C].
013 Inj. Menge [mg/R], Inj. Menge [mg/R], Inj. Menge [mg/R], Inj. Amount [mg/R]
014 not assigned?
015 u/min [1/min], Inj. Menge [mg/R], Kraftstoff Verbr. [l/h], Inj. Amount [mg/R]
016 Last [%], Bin. Bits, Bin. Bits, Volts [V]
017 Bin. Bits, Bin. Bits , Bin. Bits, Bin. Bits.
018 (no unit), (no unit), (no unit), (no unit)
019 not assigned.
020 u/min [1/min], Drehmoment [Nm], Inj. Menge [mg/R], Inj. Amount [mg/R]
021 (keine Einheit), Bin. Bits, Bin. Bits, Bin. Bits.
022 (no unit), Binary bits, (no unit), (no unit)
023 (unitless), (unitless), (unitless), (unitless)
024 not assigned.
025 not assigned.
026 Text
027 revolutions per minute [rpm], speed [km/h], , speed [km/h].
028 Arbeitstakt [%], Arbeitstakt [%], Druck [bar], Bin. Bits.
029-034 not assigned/available.
035 revolutions per minute [RPM], operating cycle [%], temperature [°C], voltage [V].
036-040 not assigned.
041-079 not available.
080-082 not assigned.
086-124 not available.
125, [ABS 1], [Station Wagon 1], [Airbag 1]
126 [KLIMA 1], , , [Elektr. ZE 1]
127-129 not occupied/available.
130-189 not available.
190-199 not verified.
200-255 not available.
Translated on 18-07-2026, 19:03.
