Search for label file
klopfer
2007 Audi A4 Avant
Post26-05-2004, 22:37    Subject: Search for label file Quote
Hello fellow DIY enthusiasts,
Does anyone have a label file for the STG "4A0 907 401 P" that they could share with me?
What actually happens if VAG-COM doesn't find the correct file for my control module (MSG)? Will it then use a similar one? Some of the values seem implausible to me, and I want to make sure that I'm not misinterpreting the analyzed data.
Sure, here's the translation:
"Thank you in advance."
Thomas.
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Uwe@Ross-Tech
Post27-05-2004, 4:48    Subject: Search for label file Quote
VAG-COM displays which label file is being used. If no suitable match is found, 'none' or 'no' is displayed, and the labels are then an estimate based solely on the data.
Please tell me your make, model, and year. Here are some label options that might be suitable for your engine: 3B1-907-401, 4B1-907-401, or 4B2-907-401. All of these are compatible with engine code AKE.
-Uwe-
klopfer
2007 Audi A4 Avant
Post27-05-2004, 9:54    Subject: Search for label file Quote
Hello Uwe,
MKB is AEL and the year of manufacture is 01/1995.
VAG-COM also always says that it doesn't have a label file (none).
Thomas.
No new posts Find Label File "8E0-614-111-EDS.LBL" On-Board Diagnostics (OBD)
No new posts Label File für STG 038-906-019!!! Diesel Engine Technology
No new posts Label Files: Definition & Examples Diesel Engine Technology
No new posts Label File 2.6L ABC On-Board Diagnostics (OBD)
