Tank is empty, starts very poorly!
Sagem
Post05-06-2004, 23:05    Subject: Tank is empty, starts very poorly! Quote
Whenever my Golf car is on reserve overnight, I have to play the organ for a minute in the morning to get it started.
Can anyone tell me what's wrong?
Thank you.
Daniel
Post06-06-2004, 8:29    Subject: Tank is empty, starts very poorly! Quote
likely either air is being drawn in somewhere on the fuel lines, the diesel filter (temperature-controlled valve in the return, seals), or the crankshaft seal of the fuel pump.
When the tank is almost empty, the fuel column in the line naturally 'sucks' more... Also, check the fuel lines (rubber hoses between the injectors) too.
Search function.
Hello, Rainer
Sagem
Post06-06-2004, 17:08    Subject: Tank is empty, starts very poorly! Quote
I have already checked the return hoses, and I have replaced the diesel filter.
I was planning to upgrade the pump to 12mm anyway, and the ring will be replaced anyway.
But the valve is a good idea.
THANKS
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Documentary: Fuel Drop After Reserve (1999) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts TDI Starting Problems: Golf 3, LOG, MWB 5 Upload
No new posts Cold Start Problems: Car Won't Start? Diesel Engine Technology
No new posts Renault 1.9 DTI: Starting Problems? Diesel Engine Technology
No new posts Golf 3 TDI: Cold Start Problems & Solutions Diesel Engine Technology
