massive startprobleme | Posts 16+
Go to page: Previous  1, 2
Post29-05-2004, 21:14    Subject: Quote
joergs wrote:
What about the KW screw, though? Has it been checked yet? It could really be the cause, and ignoring it could become very expensive!
. . . have you ever checked the timing
Or simply use VAGCOM to log the injection start values.
If something is jumping unexpectedly (and the pump and pressure relief valve must be working correctly!), that confirms the suspicion about the KW screw.
Translated on 02-08-2026, 4:55.
Äsop
Post29-05-2004, 21:34    Subject: Quote
What's the best way to check (kW)?
joergs
Post29-05-2004, 21:45    Subject: Quote
Try using the search function. You should find a link there; it's quite interesting and well-illustrated.
Translated on 02-08-2026, 4:56.
Äsop
Post29-05-2004, 22:24    Subject: Quote
http://home.arcor.de/sgrafen/salatoel/kw_schraube/kw_schraube.html
What do you think about this?
joergs
Post30-05-2004, 7:55    Subject: Quote
That's the link I was referring to!
Äsop
Post09-06-2004, 13:18    Subject: Pump: Types, Uses & How to Choose the Right One Quote
dare to go back into the workshop!
I looked and then I looked again, and then I came to this decision (or conclusion - I think that's what I meant).
The workshop says that the fuel injection pump is not building up enough pressure.
What do you think it means, or what would be the symptoms of that?
Translated on 02-08-2026, 4:57.
Äsop
Post13-06-2004, 19:48    Subject: Solution: The Best Solutions for You Quote
'The pump is not building up enough pressure, which means the injectors cannot spray fuel.'
> I'm getting a new pump tomorrow, and I should have my car back then.
(But my first thought was of the death penalty.)
Translated on 02-08-2026, 4:58.
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 2.5 TDI: Cold Start Problems & Solutions Diesel Engine Technology
No new posts Starting problems Diesel Engine Technology
No new posts AAT, 2.5 TDI, year 1996, starting problems, second issue. Diesel Engine Technology
No new posts VW Golf 4 AHF: Starting Problems & Solutions Diesel Engine Technology
