madin Guest
15-06-2004, 18:16 Subject: Constant monitoring |
Hello.
I'm new here and, of course, I've already used the search function, but I couldn't find anything relevant.
Question: Do you have experience with the continuous monitoring of engine functions in a vehicle using a car PC (and, of course, VAG systems)?
What should I pay attention to, or what should I avoid doing?
Translated on 06-07-2026, 14:11.
Gremlin Guest
15-06-2004, 22:40 Subject: Constant monitoring |
My longest trip on a single charge covered over 1600 km, almost continuously (excluding stops with the motor turned off).
you need:
- a high-quality adapter -> shop
- ensure a secure attachment of your 'diagnostic device,' whatever that may be.
- enough brain to tell you: 'get off the road!'
hazards:
- Acceleration of the vehicle at -100g because you end up crashing into a tree while fiddling with your laptop.
- The vehicle accelerated at -1.5g because Aunt Erna swerved suddenly, causing the laptop to land in the footwell.
'other:'
- This whole process isn't really real-time. VAG-COM achieves 1.5 to 3 samples per second with a single measurement block. The K-line simply doesn't allow for more. With two measurement blocks, you can achieve approximately 1 sample per second. While this is usable for continuous logging, it's not suitable for a real-time display of engine speed or boost pressure.
- Analyzing such log files can take a VERY long time...
CU Gremlin.
Translated on 06-07-2026, 14:12.
Uwe@Ross-Tech Guest
16-06-2004, 1:20 Subject: Constant monitoring |
This whole thing isn't really real-time. VAG-COM achieves 1.5 to 3 samples per second with a measurement block. The K-line doesn't allow for more.
With EDC-16, it's possible to achieve more than 30 samples per second! It's even faster on the K-line than over CAN! Okay, the fault is located in the EDC-15 engine control unit, not on the K-line, and not in VAG-COM.
-Uwe-
Translated on 06-07-2026, 14:14.
madin Guest
16-06-2004, 15:10 Subject: Constant monitoring |
Thank you for the answers. So, I can do it without any problems. Don't you have to worry about the airbags deploying if the computer crashes?
Translated on 06-07-2026, 14:15.
WarLord Guest
17-06-2004, 9:10 Subject: Constant monitoring |
No, only if you're leaving the street at the same time the car crashes.
@Gremlin
'Nojo, our company laptop has already undergone quite a bit of acceleration (it was involved in an accident at 80 km/h when I left the road, resulting in an axle break, deployed airbags, and a warped frame).' The laptop was there, but it was turned off.
Best regards, WarLord.
