Loud Humming Noise at 2500 RPM
wolfi_b
Post20-06-2004, 10:15    Subject: Loud Humming Noise at 2500 RPM Quote
Hello!
I have a relatively strong humming noise in my 1Z at approximately 2500 RPM under full load. icon_redface.gif The vibration can be felt on the body of the car (steering wheel, floor pan…). icon_wink.gif However, I've had this problem since I first got the vehicle (40,000 km).
I used the search function and came across the following possible causes.
* Exhaust system: I'll check it again, but I doubt that it could cause such a strong vibration in the bodywork.
"Fuel injectors: I'll probably take them to a Bosch service center next week, but they seem to be working fine based on the sound they make when idling."
* Engine mounts: They seem to be okay, but I'm not entirely sure how to check them properly. (Should I put the car in gear and roll it forward and backward, looking for movement? I can't really tell much from that.)
I can rule out flex pipe because my B4 doesn't have one. icon_wink.gif (Possibly due to the longitudinally mounted engine?)
I can also rule out chip tuning as the cause, since the problem occurred before any modifications were made.
Can anyone tell me exactly how the engine mounts are inspected?
Does anyone know of any other causes or suggestions for this?
Thank you in advance.
PS: I visit this forum quite often because I am fascinated by the technology of TDI engines, and because I believe I have found very competent people to talk to here }.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 11-08-2026, 10:28.
Arne
Post22-06-2004, 8:10    Subject: Loud Humming Noise at 2500 RPM Quote
Hi Wolfi,
I have this: /viewtopic.php?t=6156
I wrote that to check the engine mounts.
arne
Translated on 11-08-2026, 10:30.
wolfi_b
Post22-06-2004, 13:52    Subject: Loud Humming Noise at 2500 RPM Quote
Sure, thanks!
1993 Audi 80 B4 1Z
Translated on 11-08-2026, 10:31.
No new posts Audi A3 8L MJ 1999: Rattling/Humming Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alternator Belt Squeal: Causes & Fixes Diesel Engine Technology
No new posts Strange humming noise on ASZ TDI PD engine Diesel Engine Technology
No new posts A3 - AHF: Humming at 2000 RPM Diesel Engine Technology
No new posts Loud humming noise when accelerating Diesel Engine Technology
