VAG-Com and Notebook without a Serial Port
joggigery
Post21-07-2002, 17:52    Subject: VAG-Com and Notebook without a Serial Port Quote
Can someone help me? I'm trying to access the control units (ECUs) using VAG-Com with a USB-to-serial adapter on my laptop (which doesn't have a serial port), but only the engine and central comfort control units are accessible.
What am I doing wrong, or is there anything I can change so that I can also open the other STG files? I would be grateful for any help.
Rudi
Post21-07-2002, 19:29    Subject: VAG-Com and Notebook without a Serial Port Quote
Hmm,
Since you are interacting with two control units, it seems to be working in principle.
What other devices are connected to the K-line of your car (or what kind of car is it, anyway)?
Which version of VAG-COM are you using? (When performing such tests, you should definitely use a version that has not been illegally modified.)
joggigery
Post21-07-2002, 19:49    Subject: VAG-Com and Notebook without a Serial Port Quote
Volkswagen Golf IV TDI 85kW PD AJM.
VAG-Com 81a
Michael II
Post21-07-2002, 20:18    Subject: VAG-Com and Notebook without a Serial Port Quote
Have you already checked the homepage of Uwe Ross? These issues have already been sufficiently addressed there. If you encounter any further problems, you can also contact Uwe directly (he has helped me with many things).
Tschüss
Michael II
joggigery
Post25-07-2002, 16:30    Subject: VAG-Com and Notebook without a Serial Port Quote
Nobody can help me.
Michael II
Post25-07-2002, 16:34    Subject: VAG-Com and Notebook without a Serial Port Quote
What does VAG-Com display in the top left corner?
What settings do you have?
It's strange that Uwe can't help you. Do you have a...?
licensed version?
Tschüss
Michael II
Post25-07-2002, 16:35    Subject: VAG-Com and Notebook without a Serial Port Quote
Why don't you contact Uwe Ross?
On his website, it's described which interface adapters are compatible. If yours doesn't work, then you're simply out of luck. What did you expect?
That the serial timing improves due to the additional USB stack and the hardware?
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Aussenspiegelglasheizung ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts USB Driver Issues: Asus Laptop Troubleshooting On-Board Diagnostics (OBD)
No new posts Laptop/Notebook/Netbook im Auto laden On-Board Diagnostics (OBD)
No new posts Diagnosis Interface Diesel Engine Technology
No new posts Interface for controlling the central locking system Electrical Systems, Vehicle Electronics, Multimedia
