Diode für LMM Simulation | Posts 16+
Go to page: Previous  1, 2
Post02-07-2004, 13:21    Subject: Quote
xxl wrote:
What else could it be due to?
Your engine might not accept the diode -> check the error memory?
Otherwise, it has all the standard features: turbocharger, air filter, etc.
Without a diagnostic tool like VAGCOM or at least an LDA, you'll likely continue to be groping around in the dark.
Translated on 25-09-2026, 22:33.
DocSnydor
Post05-07-2004, 7:44    Subject: Quote
I don't know if it's nonsense, I'm not very knowledgeable about electronics, but in my case, on the 1Z, it made a difference regarding the polarity! So, if it doesn't work, just try inserting the diode the other way around.
P.S.: The diode trick didn't work particularly well on my colleague's AHU either (but there was no limp mode or error message).
Post05-07-2004, 16:46    Subject: Quote
DocSnydor wrote:
I don't know if it's nonsense, I'm not very familiar with electronics, but in my case, on the 1Z, it made a difference regarding the polarity!
So, if it doesn't work, just try inserting the diode the other way around. icon_lol.gif
It's not nonsense }.
A diode installed in reverse is as good as leaving it out altogether.
Translated on 25-09-2026, 22:34.
xxl
Post05-07-2004, 16:55    Subject: Quote
My car is a big mystery.
After I had tested the car with the other diode, I left it standing overnight.
The next morning, it suddenly started behaving in a completely different way.
It ran reasonably well up to 3000 RPM, but above 3000 RPM, it suddenly had a significant power boost...
Okay, I've reconnected the faulty mass airflow sensor and also properly reconnected the EGR valve.
I'll have the diagnostic device connected at the workshop; I know the people there well.
Translated on 25-09-2026, 22:35.
No new posts VCDS Simulation: Learn and Master the Tool On-Board Diagnostics (OBD)
No new posts LMM and Diodes: A Comprehensive Guide Diesel Engine Technology
No new posts LMM Diode: How to Draw and Understand Diesel Engine Technology
No new posts Diode LMM: Authal & Co. Solutions Diesel Engine Technology
